Question about Polycom SoundPoint Pro SE-225 Corded Phone
MWI doesn't work on Polycom SE-225
MWI doesn't work on an pair of new Polycom SE-225 handsets I've just put in on our BT Meridian 1 telephone system. The BT Converse 420 phones that were on the same extensions previously were fine to work with Message Waiting Indicator, and I've confirmed that the extensions are still programmed with MWA (message waiting allowed) and LPA (lamp allowed). Might the Polycom Se-225 not suit our Meridian system?
Cheers.
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
Posted on Dec 10, 2008
I have a bt 86000 twin handset telephone and only one handset can be used to make calls.
if it is on a landline then that will be right as there is only one landline in
if it will not make a call on the other phone when the base phone is on the base then read the instructions a to how to pair that hand piece to the base
Jul 04, 2016 | BT Lands Phones
We have a meridian M7310 telephone system, and have just bought some headsets. Unfortunately we wish to use both headset, handset or speaker phone. Is this possible? Because at the moment we can only...
First of all, make sure you're plugged into the headset port of the telephone and not the handset port. Pressing the Handsfree button should change from handset to headset. You can't use the speaker phone with the headset plugged in.
May 13, 2011 | NorStar Meridian M7310 Phone
Polycom 225 SE. Can`t make a full duplex conference call.Always it works in simplex mode. Thanks. Edward
The 225 is full Duplex and I can't see any reason why it should not work. I can only suggest menu, system settings. restore default, and see if that changes anything.
What exactly is happening when you do a conference call?
Procom have a support section
manual here
http://support.polycom.com/PolycomService/support/cn/support/voice/soundpoint/soundpoint_pro_se225.html
support here
http://support.polycom.com/PolycomService/support/us/support/Contact_Us.html
worth sending them the question they can only refuse to answer or try to charge you!
Feb 02, 2011 | Polycom SoundPoint Pro SE-225
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Good luck from Headsets Direct!
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
How do I transfer a call from the Polycom SE-225 phone?
Follow these steps :
1.1
Press the function (FCN) button on the handset while on a call and then press the number "2" button. This will place the call on hold and you will hear a dial tone.
2.2
Call the number or extension of which you want to transfer the call.
3.3
Push the FCN button on the keypad and then the number "2" button and immediately transfer the call. You do not need to wait for the other party to answer.
Oct 29, 2010 | Polycom SoundPoint Pro SE-225
Message Waiting Indicator (MWI) light stays on since VoIP
There maybe different MWI options available in the phone's set up menu on the base unit. If so, see if the different options perform differently. Your phones are probably set to "FSK" (frequency shift keying) for MWI but IIRC, U-Verse uses the "Stutter" option. Also, in addition to talking to the installer, call ATT tech support. If the problem is in the signalling they may now have programming options on their end to resolve it.
Apr 26, 2010 | Siemens Gigaset 8825 Cordless Phone
I have no dial tone on my SE225 and have tested all the lines and PSU which are working. Is the phone faulty or is there some setting to adjust?
I have a polycom soundpoint pro SE-225. when i either pick up the hand set to make a call OR press the speaker button to make a call i get a dial tone for a few seconds, then the dial tone jumps up and gets real loud for a few seconds and then goes completely away and will not let me make any calls. Any ideas what the heck is wrong??
Oct 14, 2009 | Polycom SoundPoint Pro SE-225
Phone is very crackly
The handset cord needs replacing.
(The thin coiled cable that connects the hand set to the base).
Sep 28, 2009 | Polycom SoundPoint Pro SE-225
Repair of Polycom conference handsets
Hi Debbie,
Try Multimessage systems based in Potters Bar for repairs.
We repair Conference phones along with a host of other manufacturers products.
If you are local we can either pick up from you or you can drop them off and we will quote on the repair before we start.
Please call me , Paul Morgan, on 07703 270679 for more details.
Multimessage Systems
Avaya Global Repair Centre
BT Repair partner
Jan 19, 2009 | Polycom SoundPoint IP 501 IP Phone
BT Diverse Classic 3000 Telephone Handset Registration
To register new handset:
AT THE BASE STATION
1. press and hold down the PAGE button for about 10 seconds until you hear a tone
AT THE HANDSET:
1. press the SET button
2. press the INT button
3. press the * button - the base station numbers should now be displayed (1, 2, 3, 4 )
4. enter the number of the base station you want to register to
5. press the OK button, it's got two arrows on it, and enter the base station 4-digit pin number (Unless you changed this at some point it should be 0000), and press the OK button again
Jan 04, 2008 | Lands Phones
Polycom SoundPoint Pro SE-225 Corded Phone Logo
324 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
