Mita cs-2114 copier with flashing "replace unit" light
Hello
Thanks for your response. I'm having problems with entering simulation 60 mode. I press clear/stop and print while powering on. It shows 3 horizontal lines on the page counter briefly, then goes to "1". I press the 10's to get it to 60 and press start, and it makes one copy, and I believe, is not in a simulation mode. (cs-2114 copier) (Mita)
    President:
  • Office Equip... Master
  • 990 Answers
After you see "---" within 2second press"stop/clear" again thenyouwill see"00" show out then enter 60 press print
Posted on Dec 16, 2008
  • Everett Lin Dec 21, 2008
    Dear Sir; Let's start from begining,
    1, press and hold down "print" and "stop/clear" while you turn on the power.
    2, now you will see "---" on screen,WITHIN 2 SECOND, press "stop/clear" key again.
    3,now you will see "00" on screen, enter 60 with number keys or zoom keys
    4, press "print" machine will running for about 3 minutes then stop.
    5, press "stop/clear" to lock in.
    If have anywhere still not clear please let me know, I'm alway here, good luck!
    DON'T FORGET GIVE ME A GOOD RATING ! THANK YOU !
How to set a too light copy?
enter service mode and adjust simulation 100 down to approx 165
Aug 07, 2014 | Kyocera 2av82010 Genuine Mita Km2030 Opc...
C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
SHARP AL-1644
To enter the serviceman simulation mode, press the keys as follows:
Clear → Density select → Clear→ Density select
To cancel the simulation mode, press the clear key. Then enter code 14 then hit start.
Jul 28, 2009 | Sharp AL 1631 Copier
Cs-2114 all dark copies
if you replace drum meanwhile you have to replace developer too, after you replace then you have to simulated follow these steps;
1, power off,hold down"print"&"stop/clear" key while you turn on.
2,press"stop/clear" key within 2 second.
3,enter 60, press print,pess "'stop/clear" key
4,enter 73, press print, enter000000 press print
5, mode 1, enter 03 press print mode 2 & 3 all enter0 press print
Dec 12, 2008 | Office Equipment & Supplies
Code 78 makes all black copies.
when in the simulation mode you have to follow the instruction, otherwise you going to screw up whole machine, try to turn off the power and on again, see what happen.
Dec 11, 2008 | Office Equipment & Supplies
Hi!
I checked the service manual and those numbers are not error codes.I don't know what they mean, but the black pages could be several things. According to the book, the exposure lamp could be bad. Look to see if it lights up after you push the print button. If it is not on then the lamp is probably blown. If it does light up, then you have something blocking the image from being projected on to the drum. Carefully remove the toner cart., dev. unit, and then the drum unit. Look to see if there is paper jammed anywhere. It also could be the thermal fuse mounted on the lamp assy(scanner) or a bad power board(AVR PCB) or the main circut board. You should call a local service tech for an estimate. If their a decent company they won't charge you for the estimate. Good luck!
Flashing
turn off the power , hold down "print" &"stop/clear" while turning on power. now within 2 secund, press
'stop/clear" key again, now enter78, press print let it run, will be automatically stop running, when they stop running press "stop/clear" to end the simulation.
Dec 08, 2008 | Office Equipment & Supplies
When I switch on the copier display H and than 4.. please solve my problem with thanks.
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
If the machine dies enter code 14 then press start, the machine will reboot normal, if the problem persist, the fuser unit needs replacement
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Error C63
That is the same as a Kyocera Mita DC 1470.
Error C63 is a fuser related error:
Broken fixing unit thermistor wire
• The fixing unit thermistor output voltage does not exceed 0.039 V DC within 7 s after fixing control has started with the fixing temperature remaining below 100°C/212°F (fixing unit thermistor output voltage: 1.71 V DC).
I can provide for you a full service and parts manual from Mita in PDF form for a nominal fee. Contact me for more info here.
Jan 07, 2008 | Copystar CS-2114 Copier
CS-2114 Problem
"Our copier started blinking replace unit" you need to replace the PROCESS unit...not the toner, and you surely don't need to go pokng around the back of a live copier with a multi-meter!!! I just relaced one for a customer, they are the blue things where you open the front door. They were available in june of '09, e-mail me and I'll get you one (don't know price off-hand) and tell you how to reset the unit once replaced.
hanks
Oct 30, 2007 | Copystar CS-2114 Copier
62 people viewed this question
jasbo
jasbo
