Question about ASUS P5V800-MX Motherboard
Always reboot my board is an asus p5v800-mx, the problem is when i turn it on, it always went on choose--safe mode,last known configuration or start windows normally.... it goes on and on....... what would i do? i cant use my pc..... what is the problem then....
  • Graeme van Malsen
    Graeme van Malsen May 11, 2010
    What happens when you choose "start windows normally" or "safe mode"?
  • 519 Answers
This is most likely a software problem in Windows.
Try re-installing the operating system to sort out the problem.
Regards,
Graemevm
Posted on Apr 28, 2009
  • Graeme van Malsen
    Graeme van Malsen Apr 28, 2009
    Your problem is most likely a Windows system file related problem.
    Reinstalling your operating system should sort the problem out.
    Let me know if this helps or not.
    Regards,
    Graemevm.
  • Graeme van Malsen
    Graeme van Malsen Apr 30, 2009
    This is usually due to a bios setting or an error in your Windows operating system. Go into your bios setup and select "default settings" and then try boot up again. If this does not work, reinstall Windows operating system and try once more. Please let me know if you need any further help.
    Best wishes,
    Graemevm
    Scholar:
  • 99 Answers
I am guessing from your description that you are stuck in a reboot loop where no matter what option you choose the computer automatically reboots before you get into windows. If you have not tried other options then I would start with last known good configuration and if that does not work then try safe mode. The problem is most likely a driver causing problems on startup.
If safe mode works then you will need to find the driver or other software causing problems (likely the last software that was installed) and uninstall it then reboot to see if that works.
If last known good configuration works then you should not need to do anything else.
If none of it works then you will need to reinstall windows. If you have a regular windows disk (I am guessing you are running XP) and not a manufacturer restore disk then you can boot off the disk. The first screen will ask if you want to run the recovery console. just hit enter to go past that. The next screen should say that it found a previous windows install and ask if you want to repair it. Hit R for repair when you see that screen and you should not loose any data or have to reinstall any software. That might not fix the problem though which would mean that you need to do a fresh install instead of repairing the current install and you would then need to reinstall all of your software. You might also want to find out about getting any data off the drive that you do not want to loose before you do a fresh install.
Posted on Dec 09, 2008
My labtop came to a boot up screen that has the options: safe mode, safe mode with networking, safe mode with command prompt, last known good configuration, and start windows normally. i have windows xp....
Hello xderekhx716, to choose the [least] likely {Mode} in order not to "Lose any Data," you want to choose; "Start Windows in Safe Mode." If an incident 'occur' before this 'window' [Popped-Up], then you want to "Start the Computer in {Safe Mode}. This 'way if you have been "Infected by a 'Virus' or any of the Computers Configurations have been 'changed,' or "Windows Shut Down 'Unexpectedly' than Safe Mode is the 'choice,' because the; least amount" of Operating Systems, applications will be deployed at "Startup," ie. Drivers, Programs... This will 'protect' the System' from further 'damage', if there was any? You will have the opportunity to analyze the situation safely. Next, if the Computer is having 'problems' starting, or the "Operating System is not 'responding' or there is "no change, than a "message" will identify the 'still' remaining problem; "Starting Normally." Then you want to 'choose,' start Windows at the "Last Known Good Configuration" also known as "System Restore." Finally, if this was just a "simple "Shut-down?" Than, "Starting Windows Normally" is OK! Follow all the instructions "carefully" in any of the "Modes" you may need to [Choose]. I hope this information is helpful? Thanks for using FixYa, paul7of9"
Feb 08, 2011 | ASUS Eee 4G Notebook
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
When I turn on my computer it goes to either choosing safe mode,
There are many reason for a system goes to safe mode directly.here is the solution to solve the issue
Follow the steps:
Immediately begin tapping the "F8" key when the reboot sequence begins (make sure your "F Lock" key is activated.) Once the black "safe mode" screen appears, then first try selecting the option "Start Windows Normally" using your mouse or keyboard up and down keys. Allow Windows to boot, log into your profile and wait for the program to fully configure. Once that is completed, go to the "Start" button and select "reboot." If all is well, the "safe mode" will not reappear.
If that fails, then repeat the reboot sequence -- tapping the "F8" key repeatedly -- and when "safe mode" reappears, choose the "Last Known Good Configuration" selection and allow it to go through the same sequence as in the above paragraph.
If the above does not work and your system continues to first boot into "safe mode" it is possible that a setting in the boot configuration file is checked.
For that go to start -> RUN and Type in "msconfig" in the provided box and hit "enter." The "System Configuration Utility" will appear. Using your mouse or right arrow key, select the "BOOT.INI" tab. Look for the "boot options" section and the "SAFEBOOT" selection box. If it is checked, uncheck it, select the "Apply" button and then "OK."
Go to the "Start" button and select "reboot" and your machine should now boot directly into Windows.
Mar 17, 2010 | ASUS Eee 4G Notebook
My asus computer has just crashed, it wont open the vista it says windows could not start, a recent modification could be the cause of this problem, how do i get it started
press f8 key at early boot and choose "safe mode". if that boots, "last known good configuration" should get rid of bad added driver, if that won't work go to help and support in safe mode and pick an earlier restore point for when it did work.
Oct 14, 2009 | Microsoft Windows Vista Ultimate Edition
Restarting unexpectedly
Repair the windows if you have remove the last hardware install before the problem was noticed for the first time and it didn't solve the problem.
Jun 25, 2009 | AMD ASUS A7V400-MX MOTHERBOARD SOCKET...
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Laptop won't comeback on
Try safe mode.
On safe mode return the computer to an earlier date configuration.
At some point will ask if you want to do that. And say yes.
Make sure that if for some some reasons it asks you to restore the computer to factory settings, you should say no. I hope you can do this.
Mar 31, 2008 | Toshiba Satellite 1405-S151 Notebook
Asus P3V 4X DIP Switch problem
Hello. This is more a software related issue. If it were from the processor itself you couldn't power on or received weird error during Power ON Self Check. If the processor was overcloaked windows will indead try to start but fail. Therefore, if you know you haven't overcloaked the processor you should try to reinstall a clean copy of windows by booting the computer with the windows installation CD. Hope this helps, good luck and always remember to rate the solutions received from this site :)
Mar 03, 2007 | ASUS (S370L) Processor Board
ASUS P5V800-MX Motherboard Logo
118 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
