Question about iLO 2600 Television
"No Signal" on ilo-26hd
I purchased this TV today. I have satellite service. I've plugged the out co-ax cable from the DishNetwork box to the antenna connection on the back of the TV. A "no signal" message is displayed on the screen. I also attached the "video" cable from the DishNetwork box to the video connection on the back of the TV. I tried to program the "ilo" set to my DishNetwork remote, but I don't have a remote code for this TV. Can someone help me with getting this TV going? Thanks for any consideration and help! Whitzend
  • Bev Whitt Feb 26, 2007
    I've solved the "no signal" problem. But still want to be able to operate the "ilo" using the DishNetwork remote control.
    Thanks
    President:
  • 1,284 Answers
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
Posted on Feb 26, 2007
My ILO 26HD LCD tv want get but one channel
You may have to enter the "Menu" of the TV and run the set-up for the cable/antenna connection. This will scan channels and program them to the TV, then you can access them.
Failing that you may have a bad tuner, unplug the TV for a few minutes then replug it and try again.
Hope this helps!
Cheers,
Jan 23, 2010 | Televison & Video
Ilo-26HD televison problems
most of the new TV's use a SCAT plug to allow connection of a PC or laptop. I doubt that this TV has that sophistication. The ISB will not do it and neither will S VIDEO.
As for the cable you could try a male to male plug to mnake a coaxial connection. These TV's were made to a price for walmart and you got what you paid for which was a cheap TV. There was no warranty offered by Walmart for these either
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | iLO 2600 Television
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
ILO 26HD TV: After playing Playstation, the TV
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Feb 22, 2009 | iLO 2600 Television
Ilo 26HD
Well you may have to rescan for cable if you have cable if not then your tv tuner probley went out and the tv does not notice a signal. hope this helps
Sep 24, 2008 | Televison & Video
ILO 26HD
The ilo tv 26HD turns off by its self after about 20 min. of being on.
Jun 10, 2008 | iLO V27DMBX Television
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
ILO-26HD Audio & Video
I have a ilo 26 lcd tv with built in hdtv tuner and I have a red line down the center of the screen that started today. t
Feb 06, 2008 | iLO 2600 Television
ILO-26HD remote problems
I have the same problem.
Nov 06, 2007 | iLO 2600 Television
Dish network box hookup question.
Are you sure that the antenna in isn't threaded? You may be looking at the wrong jack... All antenna inputs are threaded co-axial "F" connectors. If you ARE sure, could you post a pic of the back panel?
Sep 12, 2007 | iLO 2600 Television
Televison & Video Logo
320 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
