Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Sir i we are 2 friend connected with LAN hub we want to connect via LAN. i want LAN setup between us
    President:
  • 2,110 Answers
Yes for this you both have to set workgroup name same .first connect the LAN cable to lan ports of yours...then in Network setting give manual ip addreess as 192.168.1.1 in one computer and in other as 192.168.1.2 (subnet mask would be same) .then u bath can access each other computer by sharing folder....
but you have to disbale windows firewalll
Posted on Dec 09, 2008
Sir can i connect two pcs one desktop and other laptop for sharing files bw the two and playing games bw them
There are a couple of ways you can network two computers together.
Each computer must have a network card installed together with the LAN card drivers. The two computers needs to be connected to a network hub and these computers need to be set up on the same workgroup name.
Using a network hub will allow more the two computers to be connected to a network and the number of computers that can be installed on this network depends upon the number of available ports on the network hub.
You can use a Crossover LAN cable to connect the two computers together and you won't need a network hub.
To information and how to setup a home network, please click on this link -
Home Network Guide, routers, print servers etc.
http://sites.google.com/site/networkguidedemo/home
Jun 20, 2010 | Computers & Internet
Cannot connect to internet via wireless hub to laptop
When you power up the wireless router and the LEDs are ON then the router appears to be OK and this also applies to the DSL or cable modem.
To check if the modem is configured to your ISP settings and connects to the Internet, connect the modem with a LAN cable to your laptop and check if you can connect to the Internet.
Next, the wireless router needs the wireless settings configured and then configure the wireless card in the laptop with these settings so it can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 14, 2009 | Computers & Internet
ONE LAN CONNETION AND THREE COMPUTER
Sure you can
In fact the wireless router is your best bet for multiple systems to connect to the net.
As per crossover wiring you can interlace the computers via using their USB ports.
Jul 27, 2009 | NAD L40 CD Player
How do you hook it to the internet,
hello Sir, urs is a very peculiar question.
there are man ways throuh which u can connect to the internet.
but 1st u should be registored to use any internet connection,
general an installtion CD/DVD will b given by the srvice provider,
depending uponthe type of connection, u need to switch on the appropriate device on ur comp,
those devies can be...
  • modem
  • LAN
  • WIFI
  • usb
  • bluetooth
  • etc.........
all u beed is to go to control panel then -->networks n place--> setup up a new connection...there u just follow the instructions u will get through it..
thanku ..
if u fel my anser was good then plz vote me goood marks sir..thank u
Jul 18, 2009 | Dell Latitude CPX Notebook
Siemens 4200 2 computers
Yes and No! The 4200 gives you the option to connect via USB or Ethernet. You can only use one or the other to connect. You have two options. The first DOES involve another "gadget". The second does not!
Solution #1
I realize you're not looking to use additional equipment, but a network hub, switch or router will give you what you need. You can pick up a very inexpensive router for under $50 or even better a wireless router for a few bucks more.
I recommend a Linksys Wireless Router (Model - WRT54G) as it is very user friendly and comes ready to use. Just connect the port labeled "Ethernet" to the "WAN" port of the Linksys Wireless Router. Then connect both of your computers to any of the four "LAN" ports.
Solution #2
You can connect the first computer directly to the 4200 via USB and connect the second computer directly to the first computers ethernet port using a Network Crossover cable. Without a router of hub between the two computers, a crossover cable is required to allow them to talk to each other.
Once you have them connected to each other, on the first computer open the network connection properties for your internet connection (will be the one setup during the install of the USB modem) and click "Share This Computers Internet Connection".
Now the first option is surely the most reliable and keeps the traffic separate.
Hope this help!
Jul 20, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Internet connection
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is http://192.168.1.1 Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
May 14, 2008 | Linksys Wireless-G WRT54GL Router
2 Eth Cards one for Internet & one for LAN
First of all, I would really recommend you to buy a Cable/DSL router. It is quite cheap, usualy more secure, much easier to configure and troubleshoot. Also, it does not require to have one PC up and running all the time, hense saving energy. Do you know that a PC running 24/7 may cost between 60$ and 100$ in electricity annually? This is more than the cost of a basic router!
But, since your question is about sharing your Internet connection with a PC, here are some guidelines. I will assume here that you are using Windows XP.
On PC1:
1. Connect the modem to Eth0 in the PC. Do not connect anything in the USB port of the modem.
2. Make sure that the link lights are lit both side. If they are not, you may need a cross-over cable (this is usualy not the case)
3. Configure Eth0 to get IP address DNS automatically
4. Disable (uncheck) all protocols except TCP/IP on Eth0.
5. Run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps.
On PC2:
Simply run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps. Specify and you Internet connection is through a Home or LAN network.
That should do it.
Apr 25, 2008 | Computers & Internet
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Pano mgnetwork?
gud pm keanne...hmmm here's my suggestion:
1st u need to buy 8-Port Hub/Switch
NIC or LAN Card
7 pcs UTP Wire w/ RJ45 Jack on both end (depende sa haba)
Then connect smartbro to the CPU (Built-in LAN)
Connect 8-Port Hub/Switch to the CPU (LAN Card)
Install Hub/Switch Driver (If Needed)
Connect the 6 PC to the Hub/Switch
Setup your network using Network Wizard (Control Panel)
goodluck...
Jan 29, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
SAMSUNG SMO-211QN SECURITY SYSTEM
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
http://www.retrevo.com/s/SAMSUNG+SMO-211QN+users+manual+?sub.x=75&sub.y=14
Dec 07, 2007 | Samsung Color Indoor Security Camera with...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
