Question about Car Audio & Video
Eclipse CD5425E stereo - the sound is on and I am able to change stations etc but there is no display on it to see what I'm doing!
  • 26 Answers
Try hooking the illumination wire to the accessory wire. Eclipse decks used to be really picky. That just might do the trick.
Posted on Jan 16, 2009
Rockford Fosgate stereo acting crazy. Don't get any sound when I restart the engine. Help!!
best fix is to look for a used eclipse rockford forthgate unit that works
Mar 01, 2016 | 2008 Mitsubishi Eclipse Spyder
Eclipse AVN5504D radio only displays eject cd, eject dvd, open. What is the solution, I dont have the eclipse disc.
plorer Stereo Problem - Ford Forum - Enthusiast Forums for Ford ...
www.fordforum.com > ... > General Ford Forums > General Tech
Nov 5, 2011 - The Eclipse AVN5504D stereo only displays eject cd, eject dvd, open. plus some asian writing at the top which I don't understand sorry.
Japanese navigation toyota,eclipse insert map disk solution ...
www.pakwheels.com > ... > In-Car Entertainment (ICE)
Oct 9, 2012 - 21 posts - ‎16 authors
Despite the radio having all the instructions in Japanese, it has been ... The Eclipse AVN5504D stereo only displays eject cd, eject dvd, eject ... More results from www.pakwheels.com
- avis des utilisateurs [ tradecarview ]
Jun 23, 2011 | Car Audio & Video
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
CAR STEREO HAS POWER BUT WILL NOT OPPERRATE, no sound stations on the stereo wont change no sound no clock display only comes up with 530 AM radio station
There isn't a way to repair this in your car, it is an expensive dealer repair. I recommend that you obtain a good after market replacement. You will then have a new radio with a warrenty and it will cost you MUCH less.
Mar 21, 2010 | 2000 Chrysler Concorde
Iwave fm stereo transmitter
This is a device that "Sends" FM stereo & Transmitts Radio waves, and sends sounds/music speech etc, over the airwaves to a suitable reciever an the same "Channel" You can hook up say your Ipod to it and say tune your Car radio to the "Station" it sends on and listen to ya compilations, in the car, thru the car stero system. The radio just "Sees" it as another strong station.
Jan 24, 2010 | Pyle PIFMDK6 iPod Car Stereo FM...
2003 mitsubishi eclipse
They change the radio stations and tracks on the CD, and volume. If you don't have the default stereo installed, then the wires probably aren't hooked up properly to the new radio, and the buttons probably don't work.
Apr 05, 2009 | 2003 Mitsubishi Eclipse Coupe
How can i find the fuse for my clock and stereo display?
had the same problem with my 03 eclipse. check your cigarette lighter fuse. powered on the same circuit. that was my issue
Mar 13, 2009 | 2003 Mitsubishi Eclipse Coupe
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
Need to change the 12v supply by the Radio
The Ford Focus has a stereo problem where the display blinks on and off, with or without the ignition on. This is not a power problem.
This problem occurs when attempting to store a radio station when a blank RDS signal is being transmitted.
To restore your stereo:
  • Insert a CD, stereo will turn on in CD mode.
  • Press MENU button
  • Select DEFAULT RESET by turning the right rotary knob and press to select
  • Select YES by tuning the right rotary knob and press select
  • Press BACK button
  • Press the RDS button once, display will read RDS OFF
  • Stereo will now work properly
To prevent this problem from occurring again, be sure some text is in the top line of the display when setting a stereo station. Do not set a station when the station name is blank in display.
Nov 16, 2008 | 2006 Ford Focus
Display mode is flashing
if it is anythang like the 2002 eclipse gt stereo there is 2 button on the right side of the display screen hold the right one down and it will change the mins and the other 1 will change the hours
Nov 16, 2008 | 2002 Mitsubishi Eclipse
Car Audio & Video Logo
147 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
