Question about Denon AVR-3806 Receiver
Cant get my 7.1 surround sound through HDMI audio
I only get sound for 5.1 surround but dont know how to turn on the ex surround speakers
  • Anonymous May 13, 2009
    I have the Yamaha that claims 7.1 and I installed a 7.1 configuration but only seem to get 5.1.
  • 71 Answers
Hi you wont 5.1 only on this model
Posted on Dec 09, 2008
Sound through only 2 speakers
to determine if all the amps are working use the 7.1 direct in jacks, insert audio into each jack if all works then you have a defective surround sound assy also know as a dsp board..
Mar 31, 2010 | Onkyo TX-SR875 Receiver
I just bought a Yamaha 5.1 system with rcvr RX-V365 i have HDMI to tv then HDMI to RCVR then another HDMI to DTV. Problem cant seem to get picture AND sound together through RCVR. depending on what setting...
RX-V365 doesn't support sound over HDMI. It can switch the video+audio from HDMI in to HDMI out, but can't play the sound through the speakers. You need to connect the audio separately via optical or coax digital cable.
Mar 19, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I bought the sony bdv e500w surround sound and hooked up a optical audio to my tv and that is a sony bravia but it will not work with the surround sound when i hook it up using regular audio cords it works...
im having the same problem, except im connected via audio components and hdmi...cant get sound through the speakers when the TV is on, it doesnt make any sense.
Feb 14, 2010 | Sony Audio Players & Recorders
Want to use surround sound and use dhmi cords for picture and surround sound
You will need 2 hdmi cables the ps3 a tv with an hdmi port and a audio receiver with hdmi in and out.
1:>First connect the ps3 to the tv with the A/V cables.
2:>Turn the system on and the tv on, get to the ps3 dashboard.
3:>Under the settings tab select (display settings)
4:>Select (video output settings)
5:>Do not disconnect the A/V.
6:>Connect the hdmi cable to the ps3 and tv.
7:>Then select hdmi and select change, this gives you 30 seconds to switch the tv over to the hdmi channel. Once done and you get a signal select (yes).
8:>Disconnect the A/V cable.
9:>Select what inut your tv will support 720i, 720p, 1080i, 1080p. You can select more than one and even all if it is supported by your tv.
10:>Then select hdmi for your audio output, but since your ps3 is connected to the tv only select linear PCM 2channel. Check for sound on the tv's speakers. If check is good then proceed.
11:>Power down the tv and ps3, disconnect the hdmi cable.
12:>Connect the hdmi cable from the ps3 to the input of the audio receiver and the hdmi from the tv to the output on the receiver.
13:>Turn the ps3 on, the receiver on and the tv on. Make sure the receiver is on the right channel. If it is you will see the ps3 come on the tv, and have sound on the main speakers of the receiver and tv.
14:>At this step you should be able to see and here the ps3's dashboard. Now to setup surround.
15:>Scroll to the settings tab and select (sound settings).
16:>Select (audio output settings)
17:>Select (hdmi)
18:>Select (automatic) this will select the basic surround settings that all receivers have.
19:>Hit enter and exit.
20:>From here test the surround with a game or movie.
If for any reason you should need to restart the process, simply plug the A/V cable back in and do a video reset. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 1:>Turn the system to off/standby, where only the red light is on.
2:>Then hold your finger on the front power button, it will turn on beep twice then shut back off, release finger.
3:>Then turn back on normally.
Good luck.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
Windows 7 cant hear 5.1 surround sound through laptop audio jack
Are you sure that the soundcard supports 5.1 on your laptop?
Dec 13, 2009 | Computers & Internet
Yamaha RX-V663 wont play rear surround
The best way to get Dolby sound working is to connect the components using the optical links.
As long as you are using PCM the Dolby sounds will never get to your system. It's switching the Dolby sound off as soon as it detects PCM. I think the only way you will get Dolby on is via a optical cable which should let you have bitstream.
Mar 12, 2017 | Audio Players & Recorders
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Denon AVR-3806 Receiver Logo
401 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
