Battery not charging.when it is connected its work on pc but not charging
    Novelist:
    Champion:
  • 233 Answers
Let me get this straight. The lap top works when the power adapter is plugged into it but the battery will not charge. If that is the case you would probably need a new battery.
Posted on Dec 26, 2008
Why does system battery not charge ? new battery and new charging kit show no improvement on laptop. well charged battery works but not recharging.what is wrong ?
well this is a hardware problem.in this case your charging stage is not work.i am showing you a picture in the yellow marking fat 's are shorted if you can change these components the issue will be solved.sorry for bad english.
Jun 18, 2014 | Dell Inspiron Mini 10 N450
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
How do I charge the battery of my ACER note book PC? What is the correct manner to charge it? Should I always plug the Note Book PC into the main AC when I log on to the computer?
Yes you should when the battery is low.
You can check the amount of charge in your battery by -
Open Control Panel - Power Options - click on Power meter tab - un-tick Show power levels on each battery.
Apr 14, 2011 | Acer Aspire One PC Notebook
HOW DO I CHARGE MY NUVI 1450 ?
use small size USB cable, connect with PC
Mar 28, 2011 | Garmin GPS
Can't charge battery
Remove the battery and try if the PC turn on connecting to direct currrent.
If it turn on (whitout battery), the issue should be a connector problem or a damaged internal recargher.
Oct 19, 2009 | Toshiba Satellite A75-S2112: A75-S2112...
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Pavilion zd8000 battery will not charge charging indicator light flashes and the mains light remains constant. Renewed battery, tried another mains adaptor still will not charge. Laptop works whilst...
sounds like the battery may be bad. I would first suggest trying a replacement battery and see if it will charge if so problem solved; if however a replacement battery (that is known to be good) still does not work it is possible that your battery charger on your laptop has gone bad, which is possible but very rare.
Aug 01, 2008 | HP Computers & Internet
Computers & Internet Logo
David Payne
David Payne
