Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Kitchenaid built in dishwasher superba suddy glasses
After washing full dishwasher ,glasses always have suds in them when you first fill them with drinking water
I always have to rinse and rub by hand before I use dishes from this washer. I could feel a film on them from day one. A Kitchenaid repair guy came to look, but didn't do anything other than tell me to turn the hot water for the house up exceptionally high. (How is this an "Energy Saver" dishwasher then?) He also tried to convince me that the problem might be that our dishes weren't greasy enough.
Posted on Sep 05, 2009
I recently found out that I was using way too much soap. I was told by the repair person to use no more than 2TBSP in the main compartment and not to put any in the extra one. He said if there are suds inside you are using too much soap, so maybe that will help.
Posted on Sep 02, 2009
Soaps suds persist at end of washing
Try using "Finish" dishwasher tablets with the power ball. And make sure your rinse agent tank is full.
Aug 24, 2014 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid superba dishwasher does not pump water through sprayarms. Water comes in and empties
Welcome to FixYa,
It may be a seized wash pump, worn wash impeller or simply a plugged up pump preventing a proper wash cycle.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undesolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it. It may not be your model, ( Most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air ) but it is the same procedure.
When you`re finished run it through a test cycle and see how it goes.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Aug 19, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
We discovered broken glass dish in bottom of dishwasher with some pieces below the bottom pump area. Shortly after the washer is making a louder noise during operation time. The water pump is quite when...
sounds like you have broken glass in the wash pump you will have to remove pump from sump and clear also check the drain pump.good luck let me know how it goes
Jun 22, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Suds are left in the bottom after the cycle
Suds should not be present in a dishwasher. Automatic dishwasher soap is not suppose to suds at all. If you do have suds it is from some soap like a hand washing or dawn that got in there by mistake.
To clear it out pour some vinegar or cooking oil in the bottom and run the dishwasher for about 5 minutes, then cancel. If the suds are not gone repeat.
Apr 30, 2010 | KitchenAid Dishwashers
How do you clean the front door glass in between the pains of our range... it is a superba...
You must remove the galss assembly. Usually you remove the handle and that loosens the glass assembly and the door front. Take it off the range and lay the door on the floor to make it easier.
Sep 22, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid Superba Dishwasher clogged or jammed with broken glass
You will probably have to get at it from the bottom, possibly the back of the washer. Here is a link to your repair manual.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kitchenaid_dishwasher_product_list.html
Feb 02, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Superba Kudso15l551
check the check valve it may have something in it.
Jun 10, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
295 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
