Question about Funai TruTech DVDVCR Dual Recorder
Problem in Power Circuit of FUNAI VCP-VIP 5000A MK6
I have got some problem in Power Circuit of my FUNAI VCP-VIP 5000A MK6.How & where to repair it?
How to troubleshoot Funai LF320FX4F DS1 that will not power on
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 10, 2015 | Funai Televison & Video
Funai TV will not stay on. It turns on for 1 second and then turns off. Red standby light blinks on and of, what can I do?
Either the power driver board is faulty, or it has a humidity sensor in it, which turns it off. Move it to a very dry place for a few days, then try it again and it might work.
Jan 19, 2015 | Funai Televison & Video
Funai magnavox model#37md359b-7 when turned on for amp fuse blows on circuit board
Could be 100 things. Do you see any burnt components or burnt spots on the board? Probably no way for you to fix this unless you have the electronics repair skills unless you visually spot a short on the board like a loose screw that ended up laying on a couple of components etc.
Feb 18, 2013 | Funai Magnavox 19" Class 720p 60hz LED TV...
FUNAI DRV-B2737 HAS NO POWER AT ALL, NOT EVEN 'ON' BUTTON LED. CAN IT JUST BE INTERNAL FUSE BLOWN?
It can be a fuse but unit has to be opened to see---if fuse is good replace the player as cost for repair would be too much if power supply is bad.
May 01, 2012 | Funai Televison & Video
Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED] *** 'COMPONENT_TYPE_WININET' value:...
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
Aug 16, 2010 | Yahoo Messenger
My 32 inch emerson powers up and cuts off after a few seconds.
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again. d66cb18.jpg
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com:
http://www.tvtechcenter.com/xcart/search.php?mode=search&page=1 It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15.
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Sep 10, 2009 | Emerson LC320EM8 32 in. LCD TV
How do you remove the Rosen Rvp9800 VCP from a Pontiac Montana. It just quite functioning I checked the fuses, however it's like there is no power to it.
hi
You can simply remove the VCP and install a DVD player in its place. You can use the existing RCA's and get power there too. I have done a few and every time I have also had to add a video amplifier as well. The signal out of most DVD's isn't strong enough and you get a mostly garbled and black and white picture. If you don't want to loose the VCP, hardwire the DVD into the video's auxillary input jacks.
regards
Jul 04, 2009 | 2000 Pontiac Montana
Funai TruTech DVDVCR Dual Recorder Logo
29 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
