This TV is fine except that the image is too low on the screen. Such that the crawl on the bottom of an ESPN screen is mostly not visible. How do I fix that?
SOURCE: Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
SOURCE: White areas on bottom of screen have blue above them.
Probable blue CRT convergence or clouded blue CRT.
