Question about Crane Pig Humidifier
No moisture going into the room.
I received a used Crane Pig Humidifier which was pretty much new but it doesn't seem to work. I've had it on for about 2 hours in my daughter's room but there is nothing(no mist) coming from the pig's ears. I hear the motor gently running and the green light is on but... nothing. My daughter has had pneumonia 3 times and I want to make sure this will help her. Please help? THANK YOU!
2 Suggested Answers
  • 94 Answers
SOURCE: I have a Cool Mist Nursery Humidifier - Pig by
yes call the MFG.
Posted on Apr 30, 2011
For some reason after 2 uses it has decided to stop pushing the moisture up and the whole unit got very hot including the tank of water?? I have used humidifiers for the last 30 years and thought this...
stop pushing the moisture up? I feel you may have shorted out the unit. ultrasonic humidifiers differ from old humidifiers that relied on a motor and a little rod that sticks in to stir and disperse water droplets. (the old ones were designed to get wet).. Now they are little small vibrating disks and a fan to break down water molecules. the unit is designed to get the moisture into the room. but if it starts to **** the moisture back into it's self from the fan in the bottom. then no good can come. I messed up my first one from not knowing to keep moisture out of the bottom. but a good return policy does wonders! :)
Dec 23, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
Humidifier filled with water, but red light is on
If you overfill it, the red light goes on. just dump a little out and it should go green. Worked with my crane duck humidifier. Hope it helps
Feb 01, 2010 | Crane Humidifiers
I have a WHITE residue all over the room where the humidifier is? what is this?
From the troubleshooting section of the manual(http://www.crane-usa.com/manuals/HumidifierManual2008.pdf): White dust appears and settles outside the humidifier: ? Area tap water may have too many minerals, change to filtered or distilled water.
Jan 14, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
No matter what setting is put on furnace humidifier, moisture forms on windows.House is only 6 years old and does have a lot of windows.
Hello WPwilkers, Well there's good news and good news!
First off, you should probably use the lowest possible setting as your house being so new, is likely pretty "air-tight" and as such, doesn't have a lot of air infiltration (gaps and drafts) hence the reason you're seeing moisture on the windows.
Now, I would also use a hygrometer, just like your parents likely had hanging on a wall somewhere in their house. It will give you a better idea of the moistur (humidity) around the house. My guess is that you're already at the 60%+ level of humidity.
I suggest that you turn "OFF" the furnace mounted humidifier, until you no longer see moisture on the windows. That will allow the house to adjust and get back to normal humidity levels.
Then you can start by setting the humidifier on the lowest possible setting and keep an eye on the moisture levels in your coldest room of the house, as that is where you'll first notice the excessive moisture on the windows (just the way it works - cold rooms get condensation on the cooler windows first).
If you don't have the humistat (the control for the furnance mounted humidifer) mounted next to your heating and cooling system thermostat, you should do that - it will make it easier to adjust and also will provide a more accurate reading for the humifier to operate properly.
Some Thermostats have the ability to add a humidifier on it for integrated controlling of the furnace humidifer. Check your Thermostat and Furnance owner's manual for details.
I used to have the same problem and found that by moving the humidifer control from the utility room (mine was in the basement of my house) to the living space, it made a big difference. Since most people's homes have unfinished basements and that's where the HVAC system is located, it doesn't get the same humidty readings as an occupied living space.
The other reason that you tend to get moisture (condensation) forming on windows is that the Percentage of humiditfication is set manually with the humidifier control, and yet, the outside (and inside) air temperature vary and the difference between them can cause the humidity levels to go from very dry to very moist, in a day or two.
I tend to wait until I notice that the air inside the house is getting dry and then turn on my humidifier, once the cold winter days have taken hold. In summary, nothing wrong with your unit, just mother nature and a well built (most air-tight) home are giving you higher levels of condensation than most older homes. Gradual adjustments, once you turn the humidifier off for awhile, should get you the desired results.
I hope you find this Very Helpful and best regards!
Dec 17, 2009 | Honeywell HE365 Humidifier
Only light moisture even at high setting
Link to Manual:
Filters can get dirty pretty quick with the use of tap water. I attached the manual for you so that you can clean it.
Personally, i replace my humidifier filter at least once every 2 months.
Good Luck.
Mar 15, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
Moisture not coming out
i realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Jan 20, 2008 | Bemis Whole House Digital Humidifier ED11...
Humidifier blows out dust
As the previous poster said, it's probably a problem with your water.
Are you using tap water or bottled mineral water? If so, there are minerals which get nebulized along with the water, and leaves a white, dusty, residue. I fill my Crane Pig humidifier with DISTILLED water, which is pretty pure. Make sure that the water is DISTILLED ONLY, since some of the water companies distill the water and then add minerals back in (they almost got me here until I noticed the label that said "with minerals added"). The reason this is important is because during the distilling process, the water is boiled, evaporated, and then the vapor is condensed back to liquid. This removes any impurities or dissolved minerals from the water. You can see Wikipedia for more on this topic here.
Additionally, I use both the Crane Demineralization Filter Cartridge (which works for the penguin as well, and gets installed in place of the original water tank cap), and the ProTec PC-1 Humidifier Tank Cleaning Cartridge (which I plop into the water tank) to keep the water both de-mineralized and bacteria free. I got both products at Amazon.com.
With these 3 things, so far I haven't had any white dust residue, and the mist feels fresh and clean.
On a side note, by using distilled water, you also prevent any mineralization from building up on the nebulizer or water level sensor, which can cause the humidifier to eventually stop producing mist...
Nov 19, 2007 | Crane Penguin 1 Gallon Humidifier
Crane Pig Humidifier Logo
55 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
solver2010
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
