Back to:
Tags:
Quasar VV-1311W 13 in. Combo
Combination TV/VCR will not work from original...
posted by Gin-Gin on Feb 26, 2007
My original remote for my Combination TV/VCR will not work.
A couple of the buttons were real sluggish, so I bought a new, "universal" remote, which I did not like at all. It was too frustrating trying to "code in" the numbers, and then punch the channel up button until the oode was entereed. So, I decided to go back to my original remote, only now NONE of the buttons will work!! I have to manually push the controls on my television for anything to happen. Can anyone help me????
Comment by Gin-Gin, posted on Feb 26, 2007
To Nezro123: Thank you for your solution. I appreciate your comments. How do I "strip" my remote? Never heard of that. I somehow don't think that that will help, though, because most of the buttons worked before I put in the numbers from the new remote. That tells me that there was nothing wrong with those buttons before. Just the ones that were not working. However, I will try what you suggested.
Comment by Gin-Gin, posted on Feb 27, 2007
To nezro123: Thank you for your reply. By the term "sluggish" I mean that when I tried a couple of the buttons on the remote, they either took a long time to respond, or I could not get them to respond at all. That's why I tried to use the "universal" remote. And I think that by entering new commands and numbers, I wiped out the original code. So now I have to either go back and complete the new remote commands (which are SO frustrating!) or find out how to re-establish
the "code" for my original remote. Make sense?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
nezo123
Rank:Master Master
Rating: 85%, 8 votes
try stripping your old remote and cleaning it, i find cleaning the contacts on the pcb and the buttons themselves with aftershave is the best
Comment by nezo123, posted on Feb 26, 2007
when i say strip the remote i mean pull it apart, they are usually just held together by clips inside, if you squeeze the bottom half you can use your finger nail to prize them apart, a bit tricky but thats the way, check firstly that theres no screws hiding anywhere (look in the battery compartment),
could you please clarify what you mean by sluggish, if its what i think you mean then a good cleaning of the contacts and the buttons should sort the problem out,
hope this is of some help to you
nezo123
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Combination TV/VCR will not work from original remote.:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
TV Combos
i have a 27 in sansui - model is tvs2746a. i am askin is...
TV Combos
tv turns on screen comes on normally for about a minute or...
TV Combos
I'VE GOT A FERGUSON TV/VCR FTC2120T BUT THE REMOTE CONTROL...
TV Combos
Both speakers work on the tv if you swap them over - but...
TV Combos
remote control does not work bought new universal remote...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
