Question about Kenwood KDC-MP435U CD Player
I have a kdc-mp435u and when i connect the subs woofers to it,it dissent put out enough out put Signal to it and when im driving some times it give signal the woofers cussing them to hit heartier. I check the amp and the woofers and the wiring every thing is brand new.
  • 34 Answers
Did you plug your rca signal wires into the subwoofer ouput rca's? if so you can control the level and frequency of the sub on the face in the audio menu. if this is not the issue try new rca cables. you can run them outside the car first just to test. another issue is make sure you have proper grounding on the head unit and amp. also if your rca cables acccidently touch power they can blow a fuse or trace inside the radio causing the rca's to lose ground (you will have low audio with lots of humming noise). you can check this by jumpering a small wire from the radio frame to the outer shield of the rca jack while it is all plugged in. if the sound gets louder and cleaner you can secure this wire in place by soldering it or fixing the circuit board itself.
Posted on Jan 09, 2009
What color is the wire for the subwoofer on the Kenwood KDC-400U
The sub-woofer isn't connected to the wiring harness of the KDC-400U. It has to be wired separately. Then the sub-woofer input gets connected to the KDC-400U sub-woofer out using R/L audio wires as show on page 13 of the Quick Start Guide. The direct link to the Quick Start Guide is http://manual.kenwood.com/files/4fd9a24acb9fa.pdf . You may be able to use the wiring information on pages 12-13 to help you determine which wires aren't going to the sub-woofer.
Most Kenwood Car audio manuals are available here: http://manual.kenwood.com/en_contents/search/ .
I wish that I could give you more information.
Apr 28, 2017 | Kenwood Car Audio & Video
Kdc-mp
put a cd cleaner in your cd player see if that helps.
Feb 16, 2014 | Kenwood KDC-MP435U CD Player
I need a manuel download for the KDC-mp435u
Instruction Manual for Kenwood KDC-MP435U /KDC-X491 ftp://inform.kenwoodusa.com/...C-MP435U.pdf
Download the Document
File Size: 6.27 MB
AMPLI-TUNER LECTEUR DE ... REPRODUCTOR DE DISCOS COMPACTOS RECEPTOR DE ... Take the time to read through this instruction manual. ... Record the serial number, found on the back of the unit, ... Register your Kenwood product ... Power Selecting the Source Volume Attenuator Audio Control ...
Sep 15, 2011 | Car Audio & Video
Connected my Kenwood KDC-MP435U to my 1995 Nissan Pickup the way the manual shows to, but the stereo will not display anything. It will however take in a cd and eject it but it will not play or switch on...
ok can u be reach by phone cause me typing this to u will confuse u like hell dont worry i do not charge so u can call me and i will guide u in this its not that hard to do 1-631-384-6246 thats my cell phone i installed my radio amp and sub my self and many others. if its important and u did not figure it out call me my name is jason I am up all the time
May 18, 2011 | Kenwood KDC-MP435U CD Player
I Have Subs hooked up to my CD player and the SW settng (before the Presets) are now gone for somereason How to get it back? I got a KDC-MP435U
Press the control knob down for at least 2 seconds...this will toggle between sub on and off. If you accidentally turned sub off, it will not appear in the setting menu.
Nov 22, 2009 | Kenwood KDC-MP435U CD Player
Connecting 2 sub woofers to denon 1506 receiver
Most receivers only handle one sub at a time. If you are deadset on connecting two, you might want to consider how much power your receiver will give to each if you split the signal then determine the power of each sub. If the subs aren't the same you can be sure they will sound strange.
If they are identical and your receiver has enough power to handle them both, examine the connection the subs use to connect to the receiver and split the connection by buying a splitter at a local radioshack.
You will probably be better off using the better of the two subs instead of having both connected. Your sound quality will be more balanced and clear when it comes to bass.
Mar 03, 2009 | Denon AVR-1506 Receiver
I have an KDC-MP435U receiver with 160w kenwood speakers. can you please advise for the the best speakers for this model? can I add a subwoofer? Please advise how can I improve my car sound. I'm using this...
Yes you can add a subwoofer. you will need an amplifier and feed the signal to the amp with your subwooder output rca jacks on the back of the radio. this will give you control over the sub.
Jan 03, 2009 | Kenwood KDC-MP435U CD Player
Aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Aug 13, 2008 | Kenwood KDC-MP435U CD Player
Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
May 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Kenwood KDC-MP435U CD Player Logo
87 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
