Question about Video Game Consoles & Games
I have cheap gamepad i was working properly and one day when i was playing it sudely stoped working and now when i connect my gamepad pc shows it as unknown device
  • 903 Answers
The wiring may be frazzled. I bought my son two 'compatible' gamecube control pads so he could play his gamecube games on his Wii, but they got fried. So my new motto is to spend that little bit more if you want longevity.
Posted on Dec 09, 2008
Trying to add a Bluetooth device but it's not connecting. I read that I might have the 'ADD NEW DEVICES' turned off. but I can't seem to find where to turn it on... or if that is my problem at all.
Connecting a Bluetooth Gamepad
(MENU/123) MENU System Device Manager Bluetooth Gamepad Settings
You can play the games downloaded and installed using the Smart Hub service with a Bluetooth gamepad. Select Bluetooth Gamepad Settings, and then place your Bluetooth gamepad close to your TV. The TV scans for available Bluetooth gamepads automatically. (DualShock®4, a gamepad optimized for PlayStation, is recommended.) After scanning, you can use the Bluetooth gamepad to play games.
  1. This function is not available on certain models in specific geographical areas.
  2. If the TV fails to find your Bluetooth gamepad, place it closer to the TV, and then select Refresh. For more information on pairing, refer to the Bluetooth gamepad's operating manual.
Feb 22, 2017 | Option Computers & Internet
I got the controller conected to my laptop, but the buttons wont work when i start playing the game, its a p380 dual analog pc gamepad
you must first make sure you installed the software drivers for the controller. when you open the game, make sure that you've setup the controller in your options window. your controller name should show up if done correctly. Note: in some cases, some games aren't compatable with certain controllers, i suggest that if this is the issue, you consider getting a better supported controller, preferrably a Microsoft 360 controller. they're cheap and wireless. Bam. Toaster streudel.
May 01, 2011 | Saitek PS1000 3-in-1 Dual Analogue Pad ...
Ive just bought a saitek p380 dual analog gamepad. When playing all games if i press left it goes up and right it goes down. Ive tried everything. i have windows 7. Is that the problem do you think?cheers
it usualy the settings in the game. just try to reconfigure the x and y axes to do the right thing inside the game you are playing and that should solve the problem. i did it and it worked fine for me
regards.
Dmitry
May 21, 2010 | Saitek P380 GamePad
My logitec precision gamepad is not working in NHL 2009.
Thank you for your time and attention. Can I use a Logitech Precision gamepad to play online video games? I plugged in the USB in the front of my pc tower, but I can't control the games with it. The games only respond to my keyboard. Is there something I need to do or is it that I can't use it to play online videogames? Please help.
Mar 04, 2010 | Logitech Precision USB Gamepad PC Game...
USB GAMEPAD NOT WORKING!!!
I used one like that for my windows xp home PC (It looks just like the Playstation 2 controller) and it worked with MAME (original arcade games that were downloaded on my computer) It comes with a little CD that has the drivers on it...Look on ebay..they are very cheap coming from China and Hong Kong
Apr 24, 2009 | Video Game Consoles & Games
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
My nfl wireless gamepad want work
mat catz is a cheap brand, if youve had it for a while then its probably broken.
Dec 25, 2008 | Mad Catz Gamepad NFL Wireless Control Pad...
Help
How do you know it's not doing anything? Have you run the calibration software? If not run that software. If its not working specifically in a game you need to go the settings in the game and set up the controller to be used.
Good luck,
Lee
Jun 10, 2008 | Logitech Precision USB Gamepad PC Game...
Emulator Project64 plays Nintendo 64 Games
sory don't have a solution i have the same prob i have a logitach wingman extreme gamepad controller and it says it is working fine but dosent work with pj64 games like perfect dark or golden eye but i can play them with my keyboard wtf ?
Feb 14, 2008 | Logitech Rumblepad 2 Game Pad
Not compatible with windows vista
Hey Guyz Just Go 2 Google And Search for lgs501.exe or LGS501.exe to Download, and then download and install the application on your Vista PC .Plug in the Gamepad(Rumblepad2 or 1) In ur USB Wen ur Installing it.
THEN UR RUMBLEPAD 2 OR 1 SHOULD WORK 100% PERFECLTY + BIT MORE EFFECTS AS YOU HAVE DX10.
If youll have any problems\Errors in installing or playing or if you need any original softwares,Games,Cracks,Patches,Drivers,Help,Gamepad Drivers or Help JUsT EMAIL TO --- arjunmanoj23@hotmail.com
Nov 01, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Video Game Consoles & Games Logo
125 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
