Question about Samsung DLP HL-P5663W 56" TV
Set shuts down intertmittently
I just restart. this can happen 5or6 times over several hour period. i have pulled plug and replugged to another outlet but it continues to act up . the set was purchased11-28--04.looking for suggests.
  1. I have a slim samsung dlp HL-T4675S that I had just bought a year ago 9-11-07. It has gone bad this year around late November. Already have to replace something. Here is what I'm getting. Right now I have to have it unpluged b/c if i plug it in it will turn on by itself, in the process of being on I hear a noise around the bulb area "this is like a ziz ziz ziz while the green lamp light indicater flashes of and on. Then it will turn off by itself after about a minute. It will repeat this for approx 7 times and then all the lights will start flashing. So thats why I have it unplugged.
  2. please anybody out there any solution
  • Samsung Master
  • 5,138 Answers
Check your lamp.
Posted on Dec 09, 2008
Samsung DLP rear projection--I turn on it has only sound, then a few seconds later it turns off and then turns back on and then off. Then stays off. It used to do this a couple times but then I would get picture and then it would stay on.
My Nordic Track C2200 Treadmill will stop in mid run. The timing when it happens is random. I can pull the safety tab out and put it back in and run for a bit till it stops again. Any suggestions on...
It it completely shuts down ( console shuts down then restarts) it may be a static electricity problem. Check your outlet to be sure it is grounded. Check the plug . The ground pin may have been removed.
Jan 02, 2011 | Nordic Track Exercise & Fitness
The instructions indicate to push the outer segments down with pen, etc to set timer. I can't get the segment to go down.
Generally the segments are already pushed down when you buy timer.
Instruction usually say, pull up all the segments, and after pulling up all the segments, then push down the segments for the hours you want the timer turned OFF or ON depending on timer
51ec3fc.jpgSegments on GE 15207 timer
Oct 12, 2010 | Hardware & Accessories
Model WTW6600SBO: Machine is stuck, won't spin
I'm having the exact same problem...did you ever find a solution?
Jun 16, 2010 | Whirlpool WTW6600SW Top Load
HP m7250n shuts down unexpectedly.
your power supply is faulty you will need to replace it. If you recently installed a new hardware it could be you don't have enough power to, either upgrade you power supply or remove the hardware.
Feb 27, 2010 | HP Media Center m7250n (ED842AA) PC...
I have a WD1600 Extrernal Harddrive and yesterday my kids unplugged the outlet so everything powered down instantly. Once I plugged everything back p and restarted my computer the harddrive just spins up...
The hard drive could have been irreparably damaged. The chattering sound is the heads trying to find the beginning of the data sectors and can't. The drive will shut itself off automatically after a predetermined time period.
Jan 07, 2010 | Western Digital External USB 2.0 80 GB...
GE AEW10AJS1 Window Unit A/C Shuts Off and Trips Reset.
The condenser coils may be dirty. You can wash them out with a hose or compressed air.
Jul 20, 2009 | GE AJCQ08ACB Air Conditioner
HAVE A COLEMAN MODEL DRHSO601CB --- THE UNIT WILL RUN FINE FOR SEVERAL HOURS WITH GOOD COOLING AND THEN PERIODICALLY THE TROUBLE LIGHT WILL COME ON THE THERMOSTAT AND THE UNIT HAS SHUT DOWN. TO RESTART -...
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Toshiba P30/P35 Power keeps shutting down
An overheating occured on the unit that why it's shut off when the high limit of temp. reaches.
Try to use a lap cooler, it may reduce an overheating to the unit,
Mar 06, 2008 | Toshiba Satellite P30 P35 Series Notebook
replace the lamp part # BP96-00826A. if the lamp code on the side of the set is different replace with that lamp. you will need a tech to reset the lamp hour meter in the factory mode.
Dec 31, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
229 people viewed this question
Jerry Greenberg
Jerry Greenberg
