Question about Frigidaire GLEB27S7A Electric Single Oven
Oven door won't unlock
I have a frigidaire wall oven (not sure what the model # is, but it looks like the the single electric GLEB2757A). I turned on self cleaning for 2 hours, and for some reason the door never unlocked, and the cooling air is still blowing. The door is a not a latch, it's automatic. It's been a week, I have decided to turn off the braker to the oven after it continued for 3 days. HELP???????????????
  • 5 more comments
  • patsyc Jan 06, 2008
    was baking in wall oven, meant to change to broil but pushed Clean instead..door automatically locked. Pressed cancel, nothing happened, set time ahead by 3 hrs, then more, still nothing..pulled circutbreaker...did this several times...no heat now, but has been nearly 5 hrs. and fan is still on and door locked..book said to use Timer Control Guide..I don't have one..called co. but everyone is closed. Help
  • wingcover Jan 21, 2008
    Set oven to clean for three hours and 15 hours later I finally turned off power at breaker because the fan would not stop. When I turn the oven back on it will heat up but the fan won't stop and the door won't unlock. I manually removed the door, whcih came off easily, could not see anything to reset, push, unscrew, open... I am at a loss and can not get repairer out here for two weeks! Help.
  • Anonymous Mar 03, 2008
    I have what I think is the same oven, wall mounted with the door opening from the side, not the top. Set the oven to self-clean for 3 hours and 18 hours later the fan was still going and the door still latched closed such that I can't open it. That was a week ago; we've tired assorted mixes of circuit breakers, cancel buttons, etc, and nothing seems to work!
  • 88fox Jul 01, 2008
    tried clear, turned off power, turned off breaker, unplugged. Nothing works so oven no longer available.
  • mmaxx29115 Jul 08, 2008
    i was cooking . i turned oven off and it all of the sudden locked
  • yokikayy Aug 27, 2008
    Oven door will not close because its locked and lock light will not stop blinking (self-clean models)
  • Anonymous Mar 12, 2014
    It turns on but it does not heat up. Originally,, when installed it took four hours to reach a regular 320-420 degrees aprox. Now it stopped heating all together.
    Scholar:
  • 76 Answers
Kittyboy The first step I would recommend you to do is to turn the circuit breaker on, then set up the oven clock. Start the self clean for any amount of time, wait about 30 seconds and push the cancel button. Most of the time it helps to eliminate the problem. If it would not help, let me know and we will go further. In that case I will need the complete model number. If it is the free standing range, you can find it on the frame behind the bottom drawer. Gendos...post back
Posted on Feb 26, 2007
How do I unlock the oven door when it won't unlock after cleaning?
Hello friend, thank you for your post!
Based off the information you have provided the door on your Frigidaire wall oven is not unlocking. Performing a reset on your oven can trigger the door latch to unlock, in order to reset your oven you would need to disconnect power from it for roughly ten minutes. If this does not resolve your issue with your oven you can also hold down the clear or cancel button for 10 to 15 seconds.
Another step you can attempt is to perform a self-clean cycle and before the cycle starts cancel it and that can trick your oven into unlocking. If these troubleshooting steps do not help correct the problem it could be a faulty door latch or control panel. I hope this information has been helpful. -Matt
Mar 14, 2015 | Frigidaire 30 Single Electric Wall Oven,...
What do the error codes for frigidaire elite electri clean oven
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
Aug 02, 2014 | Frigidaire 24" Built-in Single Electric...
Remove oven door
Hello Eleanor Dailey - I understand that you will like instructions on how to remove the oven door, however may I please have the exact model number so I can assist you better in pinpointing you the instructions on how to do so.
Dec 15, 2012 | Frigidaire 27" Built-In Single Electric...
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven door will not open. Locked during baking noit cleaning?
There should be a manual unlock along the top of the door. If not unplug from wall and wait a few it has gotten hot enough that it thinks it is in cleaning mode. After a bit it should reset. I hope your turkey isn't in there! Good Luck!
Nov 27, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Frigidaire GLEB27S7A Electric Single Oven Logo
1,515 people viewed this question
Top Frigidaire Ovens Experts
Craig Butler
Craig Butler
Sal De
Marvin
Marvin
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
