Question about Dell C521 DimensionTM PC Desktop
No display on screen
I was using my Dell C521 and and left it on to go get something out of town. When I came back the computer was on but nothing on screen, so I thought it was on sleep mode so I press the power nob to get it out of the sleep state and that was it. When I turn it on the front panel under where the front USB and sound / mic ports are, light up indicator lights 1, 2, and 3. I don't know what o do to get the computer to even show the POST on my monitor. Any help will be gratefully appreciated.
  • Edgar Corrales May 11, 2010
    Are you getting any beeps at all when powering up? That is the actual POST, different computer manufacturers will use beep sounds or patterns but most are the same..for example.
    Some computers will signify a good POST by one beep, some will do it with two. Anything higher than that in frequency or lenght usually indicates a proble.
    Also, you want to be able to see the POST so you can actually see the SPLASH screen from the Motherboard/Computer manufacturer then? Like Intel or HP etc etc? Let me know more so we can narrow it down a bit more..
  • Dell Master
  • 998 Answers
Follow this link for diagnostic error codes for your model: http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/tshoot.htm#wp1064555
It appears that your video circuit has a problem, not the monitor but the graphics card or on board graphics controller.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Posted on Dec 09, 2008
How to factory reset
Hello!
Did the system come with a Factory Reset CD? If it did, use that.
Oct 28, 2013 | Dell Dimension C521 PC Desktop
When my dell c521 is powerd, it hangs after the dell screen loads and hands at the phonix bios screen.the 3 lights in front all stand on, so it does not boot into windows.what is the problem pls
It means that the video cannot be displayed on your monitor. Either your monitor is bad or your video card is bad. If you do not have a video (PCI) card installed then you are using the integrated video circuit built into your motherboard. If that's the case, you need to replace the motherboard.
May 31, 2012 | Dell Dimension C521 PC Desktop
When i turn my computer on the dell loads up and when it goes to the black screen afterwards it restarts and keeps doing that/ i have dell dimension c521. help
have you added any ram recently or anything? i would suggest booting into safe mode press f8 after the bios and try and do a roll back and shut off any un needed programs via run-msconfig-start up. also DISCONNECT ANY USB DEVICES
Mar 14, 2011 | Dell Dimension C521 PC Desktop
I have a dell c521, and I'm getting a diskette 0 seek faliure ?
Restart the computer and when you see the Dell logo.Tap on the F2 key a couple of times. You would enter the system setup.
1. Use your down arrow key on the keyboard and select the option Drives
2. Hit enter to expand the same
3. using the down arrow key again select diskette drive
4. Tap the right arrow key to switch it off.
Save the same changes by tapping on the ESC key on the top left of the keyboard.
PS. In case you have a floppy drive on the computer check if the drive is empty.
Thanks for using Fixya
Proton
Jun 17, 2010 | Dell Dimension C521 PC Desktop
I have a Dell c521 and I am trying to restore to factory settings but when I go into the the advanced boot options menu I don't have a repair mode like it is supposed to. It has other options that say to...
Use Dell PC Restore by Symantec only as the last method to restore your operating system. PC Restore restores your hard drive to the operating state it was in when you purchased the computer. Any programs or files added since you received your computer—including data files—are permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail messages, digital photos, music files, and so on. If possible, back up all data before using PC Restore.
Note: Using PC Restore permanently deletes all data on the hard drive and removes any applications or drivers installed after you received your computer. If possible, back up the data before using PC Restore.
To use PC Restore: 1 Turn on the computer and watch the keyboard status lights.
2 Immediately upon seeing the lights flash, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish restarting, and then restart the computer again.
Note: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6–10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
Cheers!
Mar 30, 2010 | Dell Dimension C521 PC Desktop
Blue screen Dell Dimension C521
This problem occures when ther is an conflict with drivers, so try to updat your Bios from dell web site orm you may try to update the video driver or have an option to replace it and try Try to boot the system safemode and chk if you get the same BSOD if not then its the video drivers
Regards
Samson Ved
Feb 05, 2010 | Dell Dimension C521 PC Desktop
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Windows media is very dark aqnd color is blurred
Techguru2009: You need to install a third party decoder. If you have then uninstall it and reinstall. You might have a conflict with the video codecs.Let me know if this helps.
Jan 24, 2009 | Dell Dimension C521 PC Desktop
Dell C521 DimensionTM PC Desktop Logo
134 people viewed this question
Alun Cox
