Question about Panasonic DMR-E50 DVD Recorder
Black and White menus and playback
Hi there. When we connect the DVD-R to the TV, the images are in black and white only. This not just for DVD playback but for menu's etc as well Any suggestions? I don't have a "switch" on the back of my player as suggested by another answer. Thank you!
    Problem Solver:
  • 10 Answers
Check in your menus to see if your can change your scart output settings, i.e. rgb
Posted on Feb 26, 2007
My DVD player only plays in black and white
Hi.
Any Incorrectly connected or defective cables can cause your DVD to display black and white images. If you Are using Component or RCA/Scart Cables follow the below steps :
You must match the colored plugs on the cable ends to the color coded jacks on your home theater and TV
Dec 30, 2017 | Televison & Video
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Black and white dvd playback
because on line out video mode are in NTSC and not in PAL how must be to play in color mode
Feb 09, 2012 | Sony SLV-D350P DVD Player/VCR
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
If you are connected on av2,make sure it is not on av2s,as this will give a b/w pic
Mar 07, 2009 | Panasonic Televison & Video
Dvd is showing black and white
You are running in the wrong format.
If you are in the USA then you need to set the Bose system to NTSC. If you are in another part of the globe then set it to PAL.
The other thing is to make sure your TV is set the correct way as well. The only other thing that will cause this is if you are trying to playback a PAL dvd on an NTSC system (and the other way around of course)
All the options you need will be in the setup menus for both the TV and Bose.
Hope that helps
That should solve your problems.
Jan 21, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
VHS play back
I am having the same split screen black and white problem. I don't think anything simple will fix this. I have looked into the unit and almost all the video processing happens on one little PC board under the DVD. I think that the capacitors on the bottom of this board are at fault, as there have been MANY noted failures of Panasonic Professional DVC decks due to these type capacitors failing.
Oct 22, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Jan 13, 2018 | Sansui VRDVD5000 DVD Recorder/VCR
Panasonic DMR-E50 DVD Recorder Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
