Question about HTC Touch P3450 Smartphone
How do I connect my bluetooth to my Ultimate phone?
I keep getting "device not found." How do I go about adding the device so it is found and works? I am clueless! Please advise!
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    ensure both are in "discoverable"mode then use default pin of four zeroes 0000 to connect
    Guru:
  • 1,049 Answers
Yep, you need to check both the documentation on the bluetooth device and the instructions on the phone. Headsets usually use 0000 but can also use 1234, computers can use anything. The amount of time to setup the trust is limited and it can be tricky to get everything looking and finding at the same time.
Posted on Dec 09, 2008
Can a device be added to a changed phone?
You can "usually" connect up to 5 devices per headset. Of course, you can only use them one at a time, So disconnect. (which is not the same as removing it from the phone.) before you connect (basicly turn the connection back on)
I keep mine connected to my phone but I also use it for my ps3 and my ipod touch.
It also depnds on the headset and the phone??
Jan 22, 2012 | Computers & Internet
Tip
How to connect Bluetooth GPS using mobile phone
<p>Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks: <br /> <p><br /> <p>1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed. <br /> <p><br /> <p>2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store. <br /> <p><br /> <p>3. Select Bluetooth GPS receiver from the list of found devices. <br /> <p>4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for. <br /> <p><br /> <p>5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false"; <br /> <p><br /> <p>6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string. <br />
on Jun 26, 2011 | Cell Phones
Tell me how to connect internet from mobile i009 to bluetooth?
At first call to your customer care executive to send you for internet settings for your mobile. When you recive the settings then do the following things-
  • Install the settings first.-go to your message inbox and find the settings message when you open it then get the install option. Just click on install option.
  • Select your internet profile-just go to your internet menu and select settings. After that select Internet Profile and select GPRS option like Airtel Gprs/ Mobile Office if you are Airtel user.
After that Install Pc-Suite and
  1. Activate Bluetooth on your mobile phone (usually found under the Settings menu) and set it to be discoverable or visible.
  2. On the PC, find your Bluetooth program manager (in Windows XP and Windows 7, look under My Computer > My Bluetooth Connections; in Vista, look for Bluetooth devices in the Control Panel; on a Mac, go to System Settings > Bluetooth).
  3. In the Bluetooth program, select the option to add a new connection or device, which will make the computer search for available Bluetooth devices and find your phone.
  4. When your mobile phone appears, select it to connect/pair it to your laptop.
  5. If prompted for a PIN code, try 0000 or 1234 and enter it on both the mobile device when prompted and your laptop.
  6. When the phone has been added, you will be asked what service to use. Choose PAN (Personal Area Network). You should then have a working Internet connection.
May 18, 2011 | Computers & Internet
How to connect to laptop?
You can connect Nokia 2690 using bluetooth and using Nokia connectivity Cable CA-101 which will fit to the USB port of your laptop.
(NOKIA connectivity cable)
Procedure on how to connect:
1. Bluetooth (This will work with the laptop with bluetooth)
First, remember to turn on the Bluetooth feature and make it discoverable by other devices (My Phone's visibility -> Shown to all) on cell phone, so that it can be detected by laptop.
Then, click on the add devices in the control panel of your computer. Click start> control panel
2. Add Bluetooth Device Wizard window will appear, tick My devices is set up and ready to be found and click Next.
3. The wizard will then search the Bluetooth devices nearby, and will show the found devices. Here the wizard found my cell phone named David. Click the device you want to add, after that click Next.
4. Ok. Here the wizard will ask whether you need a passkey to add your device, so that the communication data between laptop and cell phone will be encrypted later, here I would recommend you to either select Choose a passkey for me or Let me choose my own key. In this example, I select choose a passkey for me.
The wizard will then show the passkey and you need to key in to your cell phone. After that, the laptop will try to install the Bluetooth device. If you have Bluetooth program for your cell phone, you can install it as Windows Vista might have problem to install the device . For my case, I install Nokia PC Suite on the laptop, so I can transfer wallpapers and videos later.
Note: Also your cell phone will get the prompt to accept connection from laptop, and you need to click yes.
5. At last, click Finish to complete the Add Bluetooth Device Wizard.
6. And now, you will see the new bluetooth device added which is your Nokia 2690 phone.
Here's another way on how to connect your cellphone to your laptop.
2. Hard Connection using Nokia connectivity Cable CA-101
carloadrian_7.jpgYou can get this from any nokia stores.
Procedure:
Just connect the other end of the wire to your cellphone and the other end to the usb port in your laptop. Follow the onscreen instructions in your cellphone.
Check your laptop if your cellphone has been detected, once it's connected you can then access your pictures or other files in your cellphone. You can even transfer files.
I hope this helps.
Please rate this solution. Don't forget to leave your comments/suggestions on how I can improve my service.
Thanks..
Jan 27, 2011 | Nokia 2690 Cell Phone
I keep getting the message "Bluetooth linke is busy". What does that mean?
When you get a message like that on any cellular device, smartphone or iPhone...its because your bluetooth device is experiencing errors internally, or either your bluetooth device is connected presently with another device and keep in mind that bluetooth can only connect to one device at a time; meaning that if your bluetooth device is connected presently to any other device, that connection should be terminated in order for bluetooth to be able to search and connect to a new device!
Before you take any of these steps make sure that you have your Bluetooth settings in your phone are set secure; make sure that if any device is trying to connect, would get your attention ( any connection attempted will be prompted on your phones screen) by doing so you will not have outsiders connection to your phone without your permission!
Solution = Turn off your cellular device, and turn it on again! If you're able to remove the battery and placing it again please do so but however some devices like iphones, batteries can not be accessed! ( with such devices, using the Power On/Off botton is good enough to reset the device ).
Power off your Bluetooth headset! ( Do not turn on your device yet)
make sure your bluetooth settings in your phone is not set to automatically connect to any other bluetooth enabled device!
after your phones reset, turn on the headset using the middle botton wich is the round botton, and hold until you get a solid light and make sure BLUETOOTH IS ENABLED AND DISCOVARABLE!
if that doesn't work, hollar at me!
Sep 15, 2010 | Jabra BT2050 Bluetooth Headset
I went to my laptop conncted with my mobile phone by bluetooth.problem show bluetooth peripheal device driver not avilable.
possible drivers for your bluetooth is corrupted or missing, try downloading drivers from your Original equipment manufacturer "OEM" this should make BT work again unless you get an error after installing that drivers could not find device or device not found meaning that BT on your system is busted
Jun 04, 2010 | Microsoft Windows Vista Ultimate Edition
Bluetooth connection to my LG Renoir KC910
Go into control panel, click on bluetooth icon. Tick box 'allow bluetooth devices to find this computor.
Switch on bluetooth on phone and search for new devices. Message on computor, a device is trying to connect. click on message enter code, 0000. enter same code on phone when prompted (be quick).
Start LG pc suite, connection wizard, click bluetooth then next, enter code 0000 when prompted.
Look at phone enter same code, 0000, when prompted and hey presto all will work.
Hope this helps
Regards
Max
May 01, 2009 | LG KC910 Renoir Cell Phone
Adding my bluetooth to my phone
it needs to see the jabra..could be a timing issue...start phone (charged) start headset (charged) phone should announce it has found a device *would you like to connect?* message.....another thing..in tools you need to tell phone to look for bluetooth devices (on)
Oct 22, 2008 | LG RUMOR Cellular Phone
HTC Touch P3450 Smartphone Logo
53 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
