Question about JVC HR-XVC18B DVD Player/VCR
VCR/Tuner Video Problem - DVD Playback Issue
New out of the box (unfortunately sat around for over a year - no warranty). Whether playing a tape or just using the tuner, the video goes in and out. For a very short while it's perfect, and then it fades to snow, and ultimately blue screen. However, when playing a DVD, the audio/video is perfect. That is, until the unit warms up, and then the DVD freezes. My bad for leaving it laying around so long. Pure bad luck, because if nobody can give me an idea of a fix, it isn't worth taking to a service location. Thanks,
    Master:
  • JVC Master
  • 923 Answers
What is the unit, exactly? Make, model, etc.? Your description sounds like an AFT (automatic fine tuning) problem ... but is it hooked up right?
Posted on May 10, 2017
SOURCE:
  • 6 Answers
SOURCE: JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
Posted on Aug 03, 2007
SOURCE: DVD no video
I HAD THE SAME PROBLEM AND YOU NEED TO PRESS THE PROGRESSIVE SCAN BUTTON AND HOLD IT. YOUR TV IS OLDER LIKE MINE AND PROGRESSIVE SCAN WON'T WORK WITH YOUR TV.
Posted on Sep 09, 2007
  • 347 Answers
SOURCE: trying to copy an unprotected
hello
did you try to copy to dvd from external source? does it then work? if so might use a cleaning tape for vhs, maybe solves the problem
regards
Posted on Feb 10, 2011
dunnbiker
  • 8546 Answers
SOURCE: I've had a DR-MV5S DVD
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Posted on Feb 26, 2011
snakehead
  • 1074 Answers
SOURCE: hello can you tell me if a jvc hr xvc1u VCR DVD
Sure it has a tunner look at the back of the set you will see two male connectors one has input and the other has out put.input is for the cable comming from your cable provider and out put is where you connect to your tv.just program it to cable from the menu display and you will be able to see all your channels depaends on the amount stored in the vcr.
Posted on Mar 06, 2011
Vcr vr329 rca
Older unit and forgetting support, parts may no longer even be available. You have an issue with one of your boards, probably the one responsible for playback since it gets involved with the tape as well as tuner output. That [puppy is ready for a decent burial. Shame because I am sure it has served you well for many years. But the time has come.
Sep 20, 2017 | RCA Televison & Video
When I record a movie on the vcr it plays back snowy.
Ur VCR signal recorded free air throught an DTV converter box?Yes,this cause is normal,because VCR player have no digital tuner on the VCR player by itself,on it circuitries design.If recorded throught pay cable signal.Yes,than ur VCR video head player is dirty needed to be clean.Tries websites like Amazon.com,Ebay.com to buy a VCR video head cleaner vdeo tape.Just play it as normal as a video tape,when the video head clean,VCR will display clean head eject tape now.
Aug 03, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 13, 2009 | Televison & Video
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
VHS tapes are black and white
The tapes are B/W or one of the playback video heads is not making contact with the tape. The video head may need to be adjusted. You can take it in to get it fixed or buy a new one. The unit today is worth around $25-$30.
Jun 25, 2007 | Emerson EWD2202 DVD Player/VCR
JVC HR-XVC18B DVD Player/VCR Logo
47 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
