Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Scanner installation we want scanner installation in my system with canon_ir_3300 it asks ip address plz solve my problem as early as possible
I WANT T INSTALL SCANNER SOFTWARE IN MY SYSTEM
Posted on Dec 09, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
Press Discover. This should find your copier. Alternatively on machine go to Additional Functions > System Settings > Network Settings > TCP/IP settings > IP Address. Should see IP address there.
Read the manual included with Canon Network ScanGear Tool. You need to have a networked copier.
Posted on Jul 17, 2009
Ip address setting
This is probably like our color Canon copier...There is a screen with the network settings.available from the menu. Once you get the IP address, it is often easier to change and manage settings from the built-in web server on the copier. Open a web browser and go to http://192.168.x.x or whatever the copiers' IP address is.
Dec 19, 2015 | Canon Ir 3300 B/w Copier image Runner...
I have ir 3300 i want to connect to pc but idont no ip adders pls tell me ip adders
you go add setting,go printer setting give the foolwing ip address
192.168.1.1
Feb 07, 2015 | Canon IR 3300 Digital Copier
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Nov 02, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon IR3300 would not scan when use the
give the same class ip address to your printe and computer and install ms office soft ware, and then microsoft tools click that we find the microsoft document scanning create shortcut to the desktop.
ping the printer for computer
run the network scan gear and click on the ip, enter the ip address in the blocks and then the discover.
then scan the document for the ir 3300 scanner.
Apr 15, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Mar 15, 2008 | Canon imageRUNNER 400S Copier
Ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
240 people viewed this question
old marine
old marine
