Question about HP Pavilion dv6000z Notebook
Cant locate my mixer on my hp dv6000 - HP Pavilion dv6000z Notebook
    President:
  • 2,110 Answers
You have to install audi driver first...
Posted on Dec 09, 2008
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
Cant get my hp PAVILION DV6000 built-in webcam to work.
try using a real HP driver yet?
downloaded from whom, most non HP sites are virus pits from H3LL.
know that first.
finding drivers for obsolete systems is super hard work.
Pavilion dv6000 (is that the full partnumber or the useless series number)? post the service tag for 10x better answers.
if at HP.com (where you should have gone first) they demand that first. that is because, there are 50 LT in that series.or more
and guess what they all dont use the same chips nor cameras.
carbon date,,,, 2006 ,2007?
just about 10 years old and support ends at 10 years old
XP is dead now for 3 years why run XP
XP must have SP3 loaded, service pack 3 or USB is no good and vast other things super bad.. (old old history that)
only this matters, see those xx below, all facts here matter.
1,2,3 , all do. to match drivers; to OS. just 1 example here of 1000
9000-ppec2icix4tk32ykqb2dko55-5-0.jpg here is the dead files on this LT
deep dead.
http://h30434.www3.hp.com/t5/Printers-Archive-Read-Only/Windows-7-Upgrade-Guide-for-dv6000-dv9000-models/td-p/179816
if you read the real service manual on any HP laptop made
you learn fast there are vast variances in chips used.
and matching drivers same,
some have 3 -4 wifi chips different. in one model.
like this DV6000-1234, see that 1234, vast models exist.
world wide in fact.
Apr 07, 2017 | HP Pavilion dv6000t Notebook
Free download driver hp dv6000
You will have to check the bottom of the laptop for the exact model number. Click the link below for the location of the drivers and downloads for the hp dv6000 models:
dv6000
Hope this helps.
Zeppelinx12
Mar 18, 2011 | Computers & Internet
No souds
is the mute button above the keyboard pressed? Are you running windows 7? Does the soundcard show up in your device manager? Also, on windows 7, the volume mixer provides separate channels for applications, rather than devices as in xp. Click the volume icon, open mixer, and check to see if the internet and other applications are muted. I use a DV6000 and this caused me trouble since this computer had a bad GPU that I fixed, which causes the ssound to stop working when it goes bad. The computer ended up being fine, I had simply forgot about the mixer.
If that doesn't work, try re-installing the sound drivers. If that doesn't work, you might have a faulty BGA (nvidia) chip, which will have to be reflown.
Mar 29, 2010 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000 no sound
Go to start, control panel,
click sounds & or audio.
check your settings are correct in here.
Should be good then.
Regards
Richard.
Apr 28, 2009 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
