The pendulum is moving but the hands are not, I replaced the battery and still the same problem
I haven't much experience of this type of clock. A friend has such a quartz pendulum clock and I was surprised to discover the pendulum has no direct mechanical contact with the clock motor and as long as the motor draws some current from the battery the pendulum will swing due to the resulting influence of a small electromagnet.
I guess the quartz mechanism is at least electrically ok but somewhere there is a mechanical fault preventing the hands moving.
A typical quartz clock motor is fairly simple and dismantles easily to reveal only a few internal parts that can be examined under a magnifier to determine the probable fault - dust, burrs or excessive wear.
It is also worth making certain the clock hands do not bind on each other or the clock face.
SOURCE: wall clock not working
If you are sure the hands are not touching as they pass, perhaps the minute hand and hour hand are binding together at the hub. Try this: Gently pull on the minute hand by gripping its hub with the nails of your finger and thumb. It should slide forward a little (or come off). Also the same for the hour hand, to ensure it is not binding on the face of the dial.
I don't know the particular clock, but if it has a SECONDS hand, this is often the one that needs to be freed.
If all the hands are free, all should be good. If it has a seconds hand and the clock stops when this hand is going "uphill", try a fresh battery. If this doesn't fix it, remove the seconds hand and use the clock without it. Or you could try to counterbalance the hand by adding a little weight to the opposite side... this could work, but as it increases the mass of the hand also, it still might be a problem.
Another way might be to shorten the seconds hand..!
SOURCE: Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
SOURCE: I have a Westclox battery operated wall clock with
Sounds like it is just worn out.
Sometimes you can replace the generic clock works in these type of clocks. Go online and do a search for battery powered clock works, and see if you can match yours. They are removed quite easily after popping off the clock hands, and removing a nut under the hands that holds the clock works in the chicken.
Here's a link to a site that sells the clock movements...
http://www.clockworks.com/
SOURCE: I have an Elgin Westminster
I'm afraid you have to visit clock repair shop, as without close inspection it is not possible to say what's wrong with your clock.
SOURCE: we have a seth thomas
1, Wind the clock. If the pendulum still does not swing, check the hands of the clock. If the hands are touching each other, push the hour hand gently toward the clock face. If the hands still touch, gently bend the minute hand away from the clock face.
2. Examine the swing of the pendulum. If it moves, and then stops, or if it swings erratically, the clock is probably off-balance. Gently tilt the clock to one side and restart the pendulum.
Watch the swing of the pendulum. If it stops again or continues to swing erratically, try tilting the clock in the opposite direction. Tilt the clock at various angles, on each side, and front and back, until the pendulum runs smoothly and regularly.
Note the clock position in which the pendulum swings freely. Place a wedge underneath the clock in the place needed to maintain this angle. If a wedge alone will not hold the Seth Thomas grandfather clock in the proper position, try lifting the clock slightly up against the wall.
Use a screwdriver to attach a bracket to the wall at the appropriate position. Additional brackets may be needed depending on the angle required. It may also be necessary to employ a combination of wedges and brackets.
