Question about Mitsubishi VS-50111 50" Rear Projection Television
MY T.V. WONT TURN ON
I HAVE RAN DIAGNOSTIC AND HAVE ERROR CODE 22 I NEED TO KNOW HOW TO CHECK FUSES AND THEN WHAT TO DO NEXT PLEASE HELP ME ??
    Genius:
  • 1,199 Answers
This sounds like your flyback converter is burned out on the circut board....cheap part! but must be done by pro!
Posted on Dec 09, 2008
Why wont obd communicate with diagnostic reader on 2000 dodge ram 1500 5.9
You have a bus communication problem. Start by checking all fuses. Next check all connectors. Specifically the pcm connectors and ground. These are located in the engine compartment on the passenger side behind air intake. I have ha 2-3 of these trucks need either a pcm or connector for open asd relay circuit issues.
Feb 09, 2015 | Dodge Cars & Trucks
I am getting diagnostic code 22
Error Code: 22
Description: Engine Coolant Temperature circuit malfunction.
Possible Causes:
- Wiring.
- Coolant Temperature sensor defective.
- ECM.
Apr 25, 2014 | 1993 Jeep Grand Cherokee
2006 Saturn Ion wont turn over. Battery is great and starter tested good. Onstar ran diagnostic no error codes. please help me!
If you have a manual transmission, you may have a problem with with clutch pedal switch. Some GM's have a problem with faulty wiring for this switch behind dash. Only way to check is at fuse panel. Look for power going to switch, and power returning to fuse box.
Jan 06, 2014 | Saturn Ion Cars & Trucks
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
Laptop turns on but windows wont load. i ran diagnostic check and got error codes. error code 0f00:0244 uncorrectable data media or media is write protected
Please let us know which windows you are running and you mentioned that it doesnt load windows so doesnt it give you any message.
Also, Please try turnning on the pc in safe mode and let us know if its booting up there? Please follow the steps below.
1. Shutdown the pc.
2. Turn on the pc and as soon as you turn it on tap F8 key on the key untill you see advanced boot option.
3. Use the down arrow key on the keyboard and select safe mode with networking and press enter.
4. If it ask to select windows select windows and press enter.
5. It should show you the drivers loading window and then it should show you the normal screen with big icons.
Please let us know if it works and send us exact error and which windows (xp, vista)
Rashish
Aug 16, 2010 | Dell Inspiron 1000 Notebook
Washer wont drain, get f02 code. i have ran
It does not take much to damage the pump impeller or motor on these small drain pumps. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: Have you also checked all the drain lines? In particular, the drain line that runs from the bottom of the drain tub to the inlet side of the pump. Small articles of clothing can become lodged in this area and restrict drainage.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WS-65809 ERROR CODE 22
look on the center circuit board and you will see two green Pico fuses they look like resistors but they dont have any bands on them . They will have F9A04 and F9A05 on the board next to them. Check with a ohms meter if those fuses are open you will ned new convergence ICs. Thats the first thing to check are those two pico fuses when you get a 22 error on your model.
Sep 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Whirlpool Duet Stackable Dryer
check belt ..there is a broken belt switch also ckd thermal fuse .this is the white do hickey behind the lower panel behind the lint screen housing if a vent problem occurs this fuse will blow and unit declines to operate
May 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
2002 Mitsubishi VS-50111 WIll Not Stay on
FIRST Check for open fuses F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF fuses are open then convergence output circuit would be your problem.
Dec 17, 2007 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
