How do i access emu menu on starview 4 box ??
I have recently purchased a starview 4 box,
and have updated with usb update,
now i am trying to access menu so i can change the emu setting to on.
but it won't let me (by inputting 1570 code no.)
please can you help me with my problem
cheers
SOURCE: Eurovox ex5000 pvr - not able to manually update codes
the boxes have stopped auto updating so you need to insert the latest codes manually
here are the latest codes for virgin/ telewest
00 line 3F 32 37 03 D0 73 84 84
01 line C6 64 1D EF 47 5A 0E EF
i'm afraid these will definately change and new codes will have to be manuall inserted again.
untill someone develops a firmware update
Dave
Posted on Dec 01, 2008
  • 3 Answers
SOURCE: starview 4 super usb box
do a factory reset pin 0000 then re scan if that faills you need new coes ie go perental press ok then info then enter 2004 it will go to nav press ok drop down to key code 00 enter codes as folows useing on screen instructions 5c 2c 26 36 cf 81 ab 66
highlight key code 00 scroll left to key code 01 enter code as folows 9f 09 00 66 3b d2 43 8b then press ok
Posted on Feb 18, 2009
  • 54 Answers
SOURCE: starview codes for june 2009 please
What I did after loads of trial & error trying t follow peoples advice on here so not sure how much of it you need t do (Stage 2) might not be neccessary so try 1) followed by 3) & 4) first ;o) :-
1) Deleted all the channels & reset the factory settings to 0000.
Turned off the box at the plug, left for a couple of minutes & turned back on
2) I reinstalled the software at http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess (Not sure if thats necessary but I did so try this if 3 & 4 dont work without reinstalling)
3) Turned on the Box & went into the menu pressed 1570 on main screen to get into the CAS SASTEM & turned the EMU key ON
4) Reinstalled the channels using Telewest (Even tho I'm with Virgin) & voila, it worked & I can get all the channels again ;o)
Good luck - Stace
Posted on Jun 20, 2009
SOURCE: looking 4 the codes for starview 4 super usb
Subscribe to cable services, you get nothing for cheating.
Posted on Aug 18, 2009
SOURCE: starview super box usb
all stations gone black on superbox
Posted on Aug 24, 2009
What is the key emu when talking about starview box ?
before you can access the hidden menu for the emu you must have the latest firmware or update for your receiver if you do then scan after complete scan press menu then 1570 go down to emu turn on with left or right arrow key on remote then press exit exit back to main screen and all should be working
Apr 17, 2010 | StarTech.com StarView SV431USB 4-port KVM...
I cant turn my emu on, on my starview box any ideas?
have you tried to access the menu by pressing menu then 1570 then that opens a new /hidden menu scroll to bottom and turn on emu hope this helps
Feb 27, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Can someone please tell me how to put in emu on starview 5 usb 2 - i go to menu but cannot access emu - tried codes 1570 and 8989 but still only freeviw channels
Press menu. then on installation press 1570, this takes you to nagrivision underneath it says emu , scroll left or right to turn it onto on , press ok, this wiill take you to the code providers which you need to put in which ever one your with.
Jan 30, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Starview box(3 YEAR OLD)gone off,follwed instructions to factory
1st have you scanned the correct provider ex NTL, TW etc?
2nd did the scan find any channels or none at all?
EMU is the emulation to unscramble the channels, to access this in a starview press menu enter 1570 to bring up the secret menu, scroll down to Key EMU and use the <> buttons to turn on.
Exit out and select a PPV channel eg Sky Sports 1 and it will update. You are then set to go.
If no channels are picked up with the scan then check the VM website to see if there are engineering works in the area causing the problem.
Oct 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
Code for starview box
irst upate it from your pc with firmware v3.00 second press menu then type 1570 or what ever your number is to get into nagravision then go to SET DEFAULT KEY PRESS OK TURN ON KEY EMU .now exit back to tv it should say channel updating when it gets to %100 and it should work
Jun 09, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Please new codes for starview box may 2009 the box/starview codes for ireland dublin chorus ntl no sports or movies working
first upate it from your pc with firmware v3.00 second press menu then type 1570 or what ever your number is to get into nagravision then go to SET DEFAULT KEY PRESS OK TURN ON KEY EMU .now exit back to tv it should say channel updating when it gets to %100
May 27, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview3 super, 3 or 4 Irish channels only, emu switched on.
Not 100% certain that this'll work but this is what I did & hopefully it'll work for you too - good luck :-
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Feb 28, 2009 | StarTech.com StarView SV211K 2-port KVM...
Turning on EMU
Don't kno if it's the same for the Star view 4 but for the Star view 3 its 1570 from the main menu !!!
Feb 11, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview Super usb
go to. cablebox.4shered.com. ps horse236
Dec 22, 2008 | StarTech.com StarView SV431USB 4-port KVM...
Starview 4 thebox super usb
hope this is of help to you if not let me know .
press menu.
press 1570.
look down list to make sure EMU is set to ON . press ok.
code screen service provider tab should be 5A01.
00. go to the bottom of screen and change the codes saving each code entered.
go to the 00 tab and press right to 01. go to the code tab and change codes saving each code as entered.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
Dec 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
