Question about Garmin Nuvi 660 GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
My nuvi 670 touch screen is very dificult to use, especially when entering numbers. When I touch one letter or number the one next to it is entered.
  • Anonymous Jan 11, 2009
    same as above
  • Garmin Master
  • 2,130 Answers
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Posted on Dec 09, 2008
I was having a similar problem with my Garmin Nuvi 670. The screen would freeze and would become unresponsive, it turns out that the problem was the metal case surrounding the touch screen was slighlty bent in, touching the screen causing my GPS touch screen to become unresponsive. To fix the problem I took a mini flathead screw driver and CAREFULLY slightly pried the metal case that surrounds the touch screen away from the screen and now my Garmin and I are best friends again!!! Hope this will help with you touch screen problems on your Garmin Nuvi 670.
Posted on Jan 24, 2009
I have a similar problem with my nuvi 660. I discovered a temporary fix is to hold down the power button for 2-3 minutes during power up and the recalibration process is started.
Posted on Jun 29, 2010
Can not enter my "code" for my Roku
Enter code by using the Roku remote and pressing the up, down or side arrows to reach the corresponding numbers/letters on the screen. Once you have reached the corresponding number/letter, press the enter key * on the remote to enter it on screen. Then move on to the next. Hope this helps
Sep 01, 2014 | Roku HD Player (N1100)
How do I input names on address screen in all CAPS
When you are at the "Enter Name" screen while adding a contact to your Phone Book, press the "*" key to switch between modes. You can check which mode you are in by looking at the box in the upper-righthand corner.
"Abc-W" mode will capitalize the first letter of each word
"Abc-S" mode will capitalize the first letter of each sentence
"ABC" mode will enter in all capital letters
"abc" mode will enter in all lower case letters
"123" mode will enter only numbers
You may switch between modes while entering the name if , for instance, you need to switch between letters and numbers,
Nov 02, 2010 | One Touch Jitterbug One-Touch Cellular...
How do you get a new # on the phone and onto the screen?
There are several ways to enter a number into your Phone Book:
1. Call GreatCall Customer Service for assistance 24 hours a day, 7 days a week at 1-800-733-6632.
2. Create an account at mygreatcall.com and modify your Phone Book online.
3. Manually enter a number into your phone.
To manually enter a number, it depends somewhat on what model phone you have - either the Jitterbug Original/One Touch or the Jitterbug J. In all cases, you will need to open the phone and access the Phone Book menu option. With an Original or One Touch, this can be done by pressing NO until you see PHONE BOOK listed at the top of the screen. With a J, you will press YES once the option for PHONE BOOK is highlighted in the center of the screen.
Press the up arrow and you will see the option EDIT PHONE BOOK. Press YES to select. Press YES again to select Add. Now you will be prompted to type in the name of the contact using the Triple-Tap method. Each number corresponds to 3 letters. Tap the appropriate number in quick succession until you see the letter you want to enter. Use the "#" to enter a space.
Example: To enter the name "John," you would press 5-666-44-66.
Once you are satisfied with the name, press YES to select DONE. You will then be prompted to enter the number. It is recommended that you include 1, the area code, and then the 7-digit number even if it is a local number.
Example: 1-760-555-4321
Once done, press YES again. You will see the message Successfully Added and you are done!
Sep 17, 2010 | One Touch Jitterbug One-Touch Cellular...
It wont print wireless
We have to connect the printer to the network first, If it is not connected, please follow the below steps.
  1. Touch Setup (c01629002.gif ) on the touch screen.
  2. Scroll down in the Setup menu, and then touch Network .
  3. Scroll down in the Network menu, and then touch Wireless Setup Wizard . The Wireless Setup Wizard searches for networks, and then displays them in a list.
  4. Touch the name of your network.
  5. If the list does not contain your network name, follow these steps to enter it manually:
  6. Touch Enter New Network Name (SSID) .
  7. On the on-screen keyboard, touch the appropriate letters and numbers to enter the network name (SSID). NOTE: Make sure that you enter the uppercase (capital) and lowercase (small) letters exactly. Otherwise, the wireless connection fails.
  8. When you finish entering the new network name, touch Done , and then touch OK .
  9. Touch Infrastructure , and then touch WEP encryption or WPA encryption. If you do not want to use encryption (a security password), touch No, my network does not use encryption , and then go to step 6.
  10. If prompted, enter the WEP or WPA key:
    1. Touch the appropriate letters or numbers on the on-screen keyboard.
    NOTE: You must enter the exact uppercase and lowercase letters. Otherwise, the wireless connection fails.
  11. When you are finished entering the WEP key or WPA key, touch Done and then touch OK to confirm. The product attempts to connect to the network.
Once it is connected to the network or if it is alreday connected, please follow the below steps on the printer.
  2. Touch Network , touch View Network Settings , and then touch Print Network Configuration Page .
After that, please note the ip address of the printer from this printed page and follow the below steps.
Please click on Start------Control Panel---Printers Folder.
Right-click on the printer icon 8500 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
The issue will be fixed.
Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I forgot my pin and I need to unlock it
You have to go to the orig location you programmed your number. It uses the coordinates of that location in memory as a "Home" See below.
The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location.
To set the Garmin Lock on the device:
  1. From the Main Menu, touch the Wrench (Tools) icon.
  2. Touch Settings.
  3. Touch Security. (you may need to touch the down arrow button)
  4. Touch the tab labeled Off next to the Garmin Lock heading.
  5. The nuvi will prompt you to enter a four-digit pin number.
  6. Enter a four-digit code as your pin.
  7. Re-enter the four-digit pin.
  8. Go to a 'Security Location' and let the unit acquire satellites (the security location will unlock the unit if the pin is forgotten or lost).
  9. Set the 'Security Location' by touching Set.
The Garmin Lock has now been turned On.
Dec 25, 2009 | Garmin nuvi 260W GPS Receiver
I recieve a garmin as a gift @ it now has a code lock on it how can i unlock my garmin 260
The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location. (where it was orig programmed)
  2. Touch Settings.
Nov 08, 2009 | Garmin nuvi 260W GPS Receiver
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Apr 26, 2009 | 2007 Honda Fit Sport Hatchback
Touch screen not working on garmin nuvi 670
Has this been solved? Hold power switch to right for about 30 seconds then follow on screen help to recalibrate screens
Dec 11, 2008 | Garmin 010-00358-00 GPS Receiver
Problem with the touch screen on my Garmin Nuvi 350
Have you tried the "recalibrate" touchscreen command?
Press the "wrench" symbol at the main menu, then the "display" icon, and then "recalibrate".
Go through pressing the dots as requested and see if that cures your problem.
- Jim
Oct 27, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
2,639 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
