Question about Coby MP-C7085 MP3 Player
Error,usb,key HI, I have a usb 1gb coby mp3 audio player and I plugged it into a machine in work. it worked fine an could see the files on it,when i tried it on another pc ,clicked on removable disc f : , which came up when i plugged it in , i cant open it. the same thing happens when i tried it on my computer as well, I then tried to formatt it but nothing happens, I ran cmd and typed format f : and this message came up : Error in IOCTL . call . so what do i do now ?? thanks in advance for your help !
  • Anonymous Dec 10, 2008
    my pm3 when i charge it the buttons go red but after that i tried turning it on it doesn't work. is it because of the way i charge it or the problem is with the mp3?
  • gani_rasala Feb 17, 2009
    I have transcend usb not formating ,i tried cmd promt got error 'in IOCTL CALL' Plz send batter solution.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Ideas to explore further:
  • the first computer is infected with a virus that then transferred to your 1Gb Coby MP3 audio player. The virus wrote a script on the MP3, whenever the MP3 is plug to another PC, if will infect the computer and make itself inaccessible so as not to be able to be erased;
  • hardware, for some reason, the electronics of the MP3 was affected upon removal from the 1st PC;
  • you could try a format of the MP3 but that of course would delete all of its contents. Since normal recognition of Windows is not possible, pls try to download, install and run HP Flash Utility.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 09, 2008
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Sep 23, 2012 | Coby MP828 MP3 Player
Technical details and dealer in kerala ( Cochin )
Technical Details
  • Brand Name: Coby
  • Model: MP300-1GBLK
  • Digital Storage Capacity: 1 GB
  • Color Name: black
  • Battery Average Life: 8 Hours
  • Supported Audio Format: MP3 // WMA
  • Display: LCD
  • Hardware Platform: PC
  • Width: 3.6 inches
  • Depth: 0.7 inches
  • Weight: 0.2 pounds
Product Features
  • MP3 player with LCD 1 GB flash memory and USB drive
  • high-contrast LCD display with 7-color backlight
  • plays MP3 and WMA digital music files, ID3 tag support for song information display, mobile data storage function
  • convenient integrated USB plug( no cables required)
  • USB 2.0 hi-speed for fast file transfers
Product Description Coby MP300-1GBLK MP3 player 1 GB flash memory and USB drive with LCD, high-contrast LCD display with 7-color backlight, plays MP3 and WMA digital music files, ID3 tag support for song information display, mobile data storage function, convenient integrated USB plug( no cables required), USB 2.0 hi-speed for fast file transfers, black.
Batteries: 1 AAA batteries required.
Feb 02, 2011 | Coby MP300 MP3 Player
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 10, 2010 | Coby MP-610 MP3 Player
I plug my coby mp3 n the computer can't read it
Here are instructions for a solution to your frozen Coby 610 problem. This works even though the MP3 player is having problems talking to your computer. They should communicate fine after this update.
Here are the steps:
I hope that helps.
Dec 25, 2009 | Coby MP-610 MP3 Player
How do I charge my Coby Mp3 player MPC885?
Takes about 3 to 4 hours to fully charge if you have a USB 2.0 port.
Feb 03, 2009 | Coby MPC895 MP3 Player
Coby mp-833
If your adding music to the device and its not playing, its because your audio files are not the correct format. This unit only plays MP3 audio or Uncopyrighted Windows Media Audio files. You can test this by connecting the MP3 player, copy one of the sampe audio files under 'My Music' location on your computer and paste it on your mp3 player. It will play the audio fine.
How to play: Hold in play button until red ligh is steady, then press Play again to start the audio.
Make sure you remove any audio file that is not the correct format.
to check format of song:
right click the song, go to properties, under properties it will say 'Type of File', make sure this says MP3, thats the safest way to go.
Aug 22, 2008 | Coby MP-C883 MP3 Player
I cant listen to music on my mp3 player
Are the songs already on the MP3 player or are you talking about the audio files on your computer?
Error 4 is an internal error and the unit will need to be fixed. Please contact Coby Customer Service for further warranty information:
Toll-free: 800-688-2629
Jun 05, 2008 | Coby MP-C7085 MP3 Player
Can not add music
You cant drag and drop from Windows Media Player or Real Player, you have to go to the location on your computer where the audio files are stored *example - 'My Music' folder under 'My Document', copy and paste the songs from that location. Make sure the audio files are MP3 or Unprotected Windows Media Audio files as that is all this unit accepts.
May 21, 2008 | Coby MPC895 MP3 Player
Charging the coby clip 1gb m582 mp3 player
the manual says something about turning the player on when inserted into the usb port so it  can charge
Jan 06, 2008 | Coby MP-C582 MP3 Player
Computer doesn't recognize unit when connected
I am guessing there is a problem with the driver for the audio player. I have a Coby Audio Player MP-C827, and one day my brother decided to just remove it from the computer without correctly stopping it. Ever since, whenever I plug in it into my PC, it just does not open...nothing happens. And I don't have the cd to re-install the driver files. With respect to all of the above, a driver file which is needed by the mp3 is either damaged or corrupt. Contact me at ramone.williams89@gmail.com
Dec 29, 2007 | Coby MPC-848 MP3 Player
Coby MP-C7085 MP3 Player Logo
2,067 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
