Monitor loses all power and blackscreens
My monitor randomly shuts down internally. Sometimes its only for a few seconds, sometimes for several minutes or more. The screen and all LEDS go black. It then reboots and may go for minutes, hours or days. The power supply is external and feeds a steady 12.1V. The problem doesn't seem to be heat related.
I could probably fix it (I'm an electrical engineer) but I can't get the back off!
How do I do that (for a start!)
  • 1 more comment
  • steve_eckett Dec 11, 2008
    It's definately a hardware poblem unrelated to the OS. It has occurred at idle, and at full typing!
    I finally got the case off and manually inspected all components, and gave them all a good prod in case of bad joints etc. I suspect the cpacitors but they look fine. I've been running it naked for a couple of days waiting for it to fail again, but it hasn't!
  • steve_eckett Feb 06, 2009
    Update:
    I eventually found the problem. There is a small toroidal inductor that forms part of a resonant circuit that sets the oscillator frequency of the five-pin sm power converter chip. One end was imperfectly soldered and went intermittently open-circuit. The joint was visually perfect but the fault was found with an ohmmeter. The coil is wound with enameled wire which is notoriously difficult to solder - I'd guess the problem had been there from the factory. Careful re-soldering has cured the issue and the monitor has now run without fault for five weeks.
  • Solo4665
    Solo4665 May 11, 2010
    Have you got any power saving features enabled from the operating system?  Does it "reboot" when you move the mouse again?
I've experienced the same problem in a large environment and found that capacitors within the pc itself were swollen...replacing the motherboard solved the issue.
Posted on Dec 10, 2008
Power
Check for a loose power cord on the back of the monitor (quite common).
Jan 29, 2018 | Sony SDM-HS95 19" LCD Monitor
Display Shutdown After Few Seconds To Few Minutes
Hook a spare monitor to the computer to rule out the video graphics card in the computer, and sub another video cord from the computer to the monitor if possible to check your LG monitor, If the display shuts down and power light changes colour or goes out it is a power supply board, one or more capacitors open causing the power to fail, sometimes the top developes a bulge making it easy to spot.
Apr 14, 2012 | LG L192WS LCD Monitor
Picture goes black at random intervals
There are 4 c5707/5706 in the inverter transformer driving circuits, the cause of the problem was due to poor solder connection in the bias circuits of the transistors. Make sure to check that after you install the new transistors otherwise you will blowthem up. Common problem with this model. When the circuit drwas too much power from the power supply, it will shut itself off to ptotect itself.
Dec 16, 2009 | Dell E173FP 17" LCD Monitor
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor keeps shutting down...
hi im josh in cebu phils. mark the problem centeres in your video card try to check if it is in the proper temperature (not heat or  hot). check if it is seated firmly in the slot.
Feb 24, 2009 | Computers & Internet
MK241H sometimes doesn't turn on
Unplug the monitor from CPU Keep the monitor alone and see any problem. If not try to plug to some laptop and check again. We want to sort out the problem from monitor or CPU..
Dec 12, 2008 | ASUS MK241H Monitor
LCD Monitor blacks in and out for 1-2 seconds
does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
Jan 06, 2008 | Samsung SyncMaster 205BW LCD Monitor
Computers & Internet Logo
739 people viewed this question
David Payne
David Payne
