Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL Stops
My Neptune Maytag TL top loader stops when it goes unto the spin cycle. It clucks and squells and pounds on the outside so hard you can feel it and see it. It displays a code of uC. The local place I bought it tells me to big of load, then to small a load then that I have an unbalanced load I am having the same problem. i try to do another load with nothing in the washer and it stops at the spin cycle and give a UC code. There is also water left in the bottom of the washer-doesn't fully drain out.
    Genius:
  • 1,239 Answers
HI
UC means the washer cannot spin. There's a bulletin out this.
The clutch is likely the cause of these error codes, preventing the unit from spinning freely. A new clutch was introduced in production in March 2005 to improve performance and should reduce these error codes.
1. Visual verification can be made of a malfunctioning clutch by observing the lifter operation in spin. The lifters will rotate up to one complete rotation just prior to the tub starting to spin counter clockwise. Should the lifters continue to rotate while the tub spins, examination of the clutch will be necessary.
2. Inspect the 14 wire plug in the control console for loose red\white- pink- blue\white from the P3 connector. Also inspect the wires and connection point on the Tub Displacement Sensor for corrosion. Measure from PK to Wh/Bu at the P3 connector. The voltage should be approximately 1.5vdc when the tub is centered, 3vdc when the tub is pushed to the right rear of
the cabinet and 0vdc to the left front. Any variances of these voltages, the 14 pin harness connection, tub displacement sensor, and sensor connector should be checked.
Posted on Dec 09, 2008
    Genius:
  • 1,199 Answers
The belt that turns the washing barrel is broke or off its path!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, this is a known common error. The error code "uC" indicates "unbalanced condition". The determine this condition, Maytag Neptunes uses a small shock absorber like component somewhere on the middle left hand corner behind the front panel. In reality, this is a sensor. Electrically, this sensor uses small wiring clip that could loosen up in due course of time. Pls check on this. In most instances, this strut like sensor could develop corrosion. Cleaning and application of light oil such as WD40 should do the job.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
2 Suggested Answers
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune TL Stops
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Posted on Dec 15, 2008
My maytag neptune tl stops after wash cycle it will start for a few secounds then stops and will continue this start stop action till i hit the stop button
The washer is trying to go into spin but failing. The two sprag clutches are probably sticking, This usually indicates a water leak.
The seal should be replaced. The bearing and sprag clutches should also be checked and will probably need to be relubricate or replaced.
Apr 15, 2016 | Maytag Neptune FAV6800AW Top Load Washer
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune TL
The TL neptune has a small shock absorber on the middle left hand corner behind the front panel. it uses a small wiring clip that could be loose, with a type of inertia switch.
A common issue I've encountered with this machine is underloading. The snubber and springs allow a fair amount of movement. Don't do a few simple items or mixed load in this machine.
If these don't seem to help, let us know.
Nov 04, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Hi - my maytag top loader FA5800AWW is stuck on wash cycle. it won't do the spin only and it is sometimes getting stuck locked.
I feel you have a Clutch issue Google this phrase ""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Repost on that site in the Maytag forum and I will help.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The washer stops after starting the spin cycle
Google "Sticky: Neptune TL Washer FAV6800AWW"
You can get the Service Manual from that site 5 post down. At that post I discuss how to DIY the fix.
Feb 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL stops spinning mid cycle? The washer stops with 11 to 13 minutes from the end of the wash cycle and leaves water in the wash tub. We've tried shifting the load for balance but it does not...
RF_Tim
I feel you have a Clutch malfunction a very common problem with the machine. If you want to DIY the fix see my Clutch Fix post.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you need some additional help just shout back……..Rich
Jun 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune TL won't spin, continuously beeps through spin settings
if water remains in the tub it will not go into the spin cyc something in the pump clear it and try again
Aug 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Sep 24, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
