Question about Philips MRV700VR DVD Recorder/VCR
Blue screen When using the VCR side of my player, the audio plays, but the screen shows blue. I cleaned the head and I have tried several tapes that all work in other players? Any thoughts?
  • evszany Dec 10, 2008
    Nothing has really changed since it worked. It hasn't been moved or unplugged. It just plays a blue screen now. The audio still works and the DVD side still totally works. I've cleaned it and checked all the cables. I even changed the cable out to make sure the cable wasn't bad. I just really don't want to have to pay someone to fix it. I've checked all the settings and tracking. I don't know what else to do.
  • Carolyn Frisk
    Carolyn Frisk May 11, 2010
    Check connections, Are you sure you have it on the right input selection? What has changed since the last time it worked?
  • 8,596 Answers
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Posted on Dec 09, 2008
Allegro DVD/VCR combo - not reading disk & eating tapes.
Sorry I know very little about the dvd side but my experience with several VCRs is they need cleaning sometimes just like audio tape recorders and players need cleaning. Early in my days of VCR ownership the engineer I used was sick of seeing me and taught me how to clean the heads, guides and rollers myself to restore performance and help prevent tapes being chewed. Head cleaning tapes simply did not reach the parts needing cleaning though the the wet type sometimes helped.
A VCR might work normally for several months and then suddenly it would happen again. Sometimes I needed to do a clean several times in a month. I did have a Sharp VCR once and that had something called an idler reel that would "suddenly" need replacing (several times) due to chewed tapes but other than that manual cleaning did the job every time.
Later VCRs were fitted with a self cleaner that worked well and meant there was no trouble for a long time but when the self cleaner became loaded with filth they actually made matters worse.
Matter of interest, I use clean newspaper and methylated spirit for cleaning.
Oct 23, 2017 | Allegro DVD/VCR ABV511
Recording from VHS to DVDR was going fine,then I stopped getting a picture. DVD player is fine plays back recordings etc. However tape player starts to play shows picture then stops showing video and...
Possibly dirty video heads. I would suggest that you run a head-cleaning tape through the VCR deck to shift surface dirt off the heads. If that doesn't work, or it sort of works, but not satisfactorily, unplug unit, carefully remove top cover, and with the VCR deck in view, gently clean the heads with a soft cloth or special cleaning stick (these look like flat q-tips but are intended for VCRs - available from electronics/hobby stores) and some alcohol (methylated spirit will work if that's all you got - but isopropyl alcohol is recommended - available from the same places as the sticks) clean the guides (gently so as not to disturb their alignment) clean the pinch roller/capstan shaft - CTL (on the right-hand side of the drum) and FE (left side) heads as well. The whole tape path should be carefully cleaned. Refit top cover (carefully), plug unit back into power, wait until it completes its startup/loading procedure, then put a tape in. You should now have a playback picture with the sound. You only need to do this as required if head-cleaning cassettes don't work properly.
If none of the above cures your problem, then the heads are abraded/worn - let's hope that isn't the case here. This model does not use a built-in head cleaner.
Feb 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Panasonic DMR-ES35V and all is working great except it recently started showing only a blue screen when I try and play a VHS tape. Doesn't matter what kind of tape, home movie or professional it...
You can try cleaning the video heads and tape path within the VCR deck. If this doesn't fix it, then the heads are worn, or there is a fault with the head amplifier (this is part of the motherboard and nearly all surface-mounted components).
I would go with the simplest option first: check the condition of the heads, if dirty, clean them with commercially available head cleaning products such as isopropyl alcohol (IPA) head cleaning solution.
Jan 25, 2011 | Panasonic DMR-ES35VS
My VCR won't play my movies! The tapes are fine its just when I put the tape in it just shows a scraggly screen. Everything is plugged in but my movies won't play. What do I do?
If the vcr is running the tape, your video head is probably dirty, try using a cleaning tape if you have one. The second option is use a brand new blank tape T120 and set the the machine to sp speed (2hr running time) and let the tape run the full course. The third option is to remove the lid of the vcr and carefully clean the video head with a swab dipped in rubbing alcohol rotating the head by hand as you proceed allowing several minutes to dry before loading your tape.
Dec 21, 2010 | Sharp VC-H810U VHS VCR
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
How can i fix my vcr dvd deck when i play the vcr it doesnt show
It really depends on the problem. I assume since you used a head cleaning device that the tapes are playing, but not clear correct?
Although tape cleaners like the one you used can help, they are only useful for minor problems and when used on a regular basis.
To really clean your VCR head completely you will need to remove the outer shell. After you have the cover off you will be able to see the reader head. Using Q-tips and rubbing alcohol wipe the surface clean and wipe lightly. You should be able to see a bit of discoloration on the Q-tip. Make sure to wipe off any residue with a clean dry Q-tip. While your inside blow off any dust that might be on the laser on the DVD player.
Hope this helps. Please let me know if you need anything more regarding this.
Nov 23, 2009 | Panasonic PVD4744 DVD Player/VCR
I want to play a movie on my vcr but when i puch
You will have dirt on the heads, the picture will show through when you scan as it is travelling past the heads at a faster rate. Either try using a head cleaning tape or remove the top cover & very gently use a head cleaning fluid (eg. isopropal alcahol) with a head cleaning stick or clean piece of card (Do Not use a cloth or cotton bud etc) very GENTLY with not too much pressure wipe the heads on the side of the head drum (the round center silver object) DO NOT apply too much pressure as you can damage the heads easily, wait a few minutes for the fluid to dry then try to play a tape.
Aug 08, 2009 | RCA Televison & Video
Recording on a Panasonic VCR
This problem is undoubtably dirty or worn video heads. Try using a good quality head cleaning tape. If this fails, re-post, and I will explain how to clean heads by hand.
Dave Duff
Mar 01, 2008 | Panasonic PV-V4022 VHS VCR
VCR acting strange with audio and playing
It sounds like the audio control head is at fault.
If all prerecorded tapes (movies) play with audio level jumping up and down, is is likely that the audio head is dirty. The audio head in the VCR looks very similar to a head of an old audio cassette player.
First, try to clean the audio head by running a VHS head cleanning tape. The cleanning tape will usually clean the path of all tape mechanisms..
Good Luck
Feb 25, 2008 | Panasonic PV-V4523S VHS VCR
VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Nov 08, 2007 | Philips VR330 VHS VCR
Philips MRV700VR DVD Recorder/VCR Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
