Question about Sanyo Xacti VPC-T700 Digital Camera
Zoom will not retract
In the middle of taking graduation photos the zoom froze. Unit not dropped, just adjusting the zoom to get the best picture.
Now only a quick "For Service...." message appears, then display goes to black. Battery replaced, charged. Is this indeed a disposable camera?
Very disappointed in Sanyo, 3 month warranty; 7 month ownership.
Appreciate any advise.
I took the camera apart, painstakingly removing all the screws. Within the zoom area were two small loose pieces, one appeared to be a lens, the other a thin metal cover. I placed the parts back into their place, and put all the screws back, except for the case. When I did a test to see if everything would work..... Eureka !!! No, sorry, Darn!
The camera appears to be at the same status, turns on long enough to see the "For Service...." message pop on the screen, then the camera powers off.
I will be taking the camera apart again, and will use a meter to check connections.
Will report back if there is further progress on this situation.
Posted on Dec 13, 2008
What is the difference in the optical and digital zoom?
Find the difference below
Digital Zoom
1. Digital zoom is a part of digital cameras, and camcorders, which helps to crop the entire image, and then digitally enlarge the size of the viewfinder of the portion that is needed to zoom in on
2. Digital zoom crops the image down to a centred area with the same ratio as the original, and also interpolating the result back up to the pixel dimensions of the original. this method involves cropping, hence the resolution and quality is reduced
3. Digital zoom, crops a portion of the image and then enlarges it back to size. And due to this, image quality is reduced in comparison with the original one.
4. Using the digital zoom allows the user to get closer to the subject when the photographer wants to be discreet about taking pictures, like taking a picture of a person in a graduation ceremony.
Optical Zoom
1. While taking a picture using a Camera to want to get a close shot of the subject without moving physically closer, photographers use the optical zoom.
2. The optical zoom ratio of a digital camera measures how much the lens can actually zoom in to make subjects appear closer. Optical zoom, enlarges a picture while keeping the resolution and sharpness of the picture high.
3. There is no relation between optical zoom and the resolution of the photo, as optical zoom only enlarges the whole image or the subject to a certain range. So image quality only depends upon the mega pixel (MP) of the camera
4. Optical zoom is very useful, while taking a picture of a landscape, or to get a closer view of a subject, without reducing the quality of the entire image, like taking a picture of a Rainbow in the sky.
Regards,
Ron
// Rate the solution with 4 thumbs up if the answer is satisfactory
Jul 01, 2011 | Nikon Cameras
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Lens stuck out
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 22, 2010 | Casio Exilim EX-Z77 Digital Camera
Zoom lens is stuck on my camera
Hey, my husband just fixed it! You just wiggle/bend the zoom lens, and you feel a "pop", and then the zoom retracts and you're fine! I was afraid to "break" it, but someone on vacation had the same problem and told him this solution a few weeks ago. So don't be afraid to use a little force-at least, in our case, it worked! Good luck.
Jan 26, 2009 | Fuji FinePix J10 Digital Camera
Zoom lens Motor Problem?
The suggests the zoom control failure
Only Olympus can fix it to it will have to go back.
Nov 08, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Photosmart m627 camera
It sound like a problem with the zooming mechanism, does your camera was dropped down ? In case it dosen't, since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem. Good luck!
Aug 13, 2007 | HP PhotoSmart M627 Digital Camera
Olympus Digital Camera D-490 zoom will not take pictures outdoors
It sonds like teh shutter is stuck open. If the camera is indera year old it is probably still under warranty. Take it to an authorized repair shop and they will most likely repair it for free.
Sep 25, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Sony DSC-W12 Camera
The W12 must be a European version of the W1 or W5 camera. The W12 is not available in the USA. It sounds like you have the "digital zoom" feature active. Digital zoom lowers the quality of the photo. It (in effect) reduces the megapixels applied to an area of a photo. Digital zoom should not be used if you want quality results.
Sep 08, 2005 | Sony Cyber-Shot DSC-W12 Digital Camera
Sanyo Xacti VPC-T700 Digital Camera Logo
Top Sanyo Cameras Experts
Chen Dorot
Chen Dorot
malemanguy
Level 1 Expert
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
