Question about Yamaha HTR-5660 Receiver
Surround sound problems
I am unable to get my Yamaha receiver to perform in 6 speaker mode, only stereo. It tests fine with all speakers, but when I attempt to play a DVD, or program the receiver to surround sound, it won't program for 6 speakers, just stereo. It's done this since we had to unhook the stereo in order to install our entertainment center. Any ideas?? Thanks. Randy
  • radicalx Dec 19, 2007
    I cannot get the receiver to go into surround sound. It checks the speaker levels, BUT! When it gets to the subwoofer, there's no sound. I can't tell if the subwoofer is OK or not, but I checked all cables by swapping things, and they're OK. I reprogrammed the receiver for no subwoofer, but it still did not go into surround. Only stereo, front speakers.
    Can anyone help?
    Thanks!
    Dave
Try changing your cables
Posted on Nov 20, 2007
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Yamaha HTR-5660 receiver but no surround sound
have you tried putting it in a different program mode?
Jul 04, 2009 | Jensen CS10 Speaker
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
Center speaker still not working :(
all your speaker channels are working so your problem lies with a setup fault. when you watch tv you are only feeding a stereo signal into the amp. you need to select the internal surround sound generator. you need to select either the movie or surround function. the unit will convert the stereo signal to 5.1 channel surround.
May 26, 2008 | Yamaha RX-V595A Receiver
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
TX-DS494 Surround Sound Issue
don't switch to stereo mode. switch to prologic mode
Aug 06, 2007 | Onkyo TX-DS494 Receiver
Yamaha HTR-5660 Receiver Logo
316 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
