Question about Apple iPod nano
Ipod won't turn on
Have charged the ipod up all day unable to get it to turn on recently dropped
  • lawson_a_d Dec 09, 2008
    I tried this still doesn't work. I can't even get the screen to come on. I have tried charging the battery with computer and also by electric outlet. Nothing.
    Problem Solver:
  • 15 Answers
No i was saying to check the battery by voltage tester u have tried by charging with pc or electric supply but may be its circuit broke down u can check it after u have tried the battery by tester and further i wud suggest u the right solution thanks
Posted on Dec 11, 2008
    Problem Solver:
  • 15 Answers
U HAVE DROPPED IT NOW MAY BE ITS BATTERY IS DEAD OR I WUD SUGGEST U 2 CHECK THE CIRCUIT CONNECTION AND THEN TRY 2 RESTART IT
Posted on Dec 09, 2008
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
Dead not connect charging
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 18, 2012 | Apple iPod touch Second Gen (8 GB,...
Charge the battery
Aug 13, 2012 | Apple iPod touch Second Gen (8 GB,...
It will not charge up.
Recharageable should not be stored in a discharged state.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 23, 2012 | Apple iPod nano 2nd Generation MP3 Player
Ipod will not turn on
Generally they will not power on if they are not fully charged or if they have some error in their OS, try charging the ipod and then restoring it in itunes, also what type of ipod do you have ?
Nov 18, 2011 | Apple Cell Phones
After charging your portable media player overnight, you turn it on only to find that it is reporting a low battery. Seconds later, it shuts off automatically. What might be wrong
Ifthe MP3 player battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Apple iPod shuffle MP3 Player
I don't know why stop my ipod
Greetings Aek Smarth,
Your ipod has probably overheated. Here is what you should do:
  1. Turn on your ipod and let it play until it dies.
  2. Plug in your ipod and fully recharge it.
If your ipod is unable to be turned on:
  1. Plug it in and charge it for over a day.
  2. Attempt to turn it on after this day.
After having it plugged in for a day, it should reset itself and be like normal. If it does not reset itself, than your out of luck. Thank you for using FixYa! =)
Nov 18, 2010 | Apple iPod MA446LL/A MP3 Player
How to use an ipod shuffle charge
Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
  • iPod shuffle (1st generation) - iPod Software version 1.1.5
  • iPod shuffle (2nd generation) - iPod Software version 1.0.4
download here
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
then install..
follow these instructions..
Using iPod Reset Utility
  1. Quit all running applications on your computer.
  2. Open iPod Reset Utility.
  3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
  4. Click the Reset button.
  5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
  6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
Jun 05, 2010 | Apple iPod shuffle MP3 Player
I dropped it, and now it won't turn on!
ok make sure its not locked then hold menu and the center button for 8 to 10 seconds if that doesn't work youll probably need to take it in to get repaired or get a new ipod
Oct 30, 2008 | Apple iPod nano 3rd Generation
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
