SOURCE: I have a motherboard asrock-k8nf6g-vsta,
the problem with those drivers is that YOU are an idiot. and idiots can't find the drivers on the official page....
SOURCE: Asrock ALiveNF6G-VSTA Motherboard. Unable to boot to OS
first disconnect ALL cables except power suppliy and frond panel switch. Startup and see if goes further.
dont forget to disconnect the front panel usb cables also !!!
if it goes better, connect he keyboard, reboot and enter bios to see.
etc etc
if it still hungs up at the start with all cables disconnected then a major chip on your motherboard is burnt (maybe the disk controller).
sorry i dont think a solution oher than buying a new motherboard.
SOURCE: asrock k8nf6g-vsta motherboard will not power up
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
SOURCE: I need, ASrock K8NF6G-VSTA bus
Hello
Click here to download drivers from ASrock web site
Good Luck
SOURCE: I have an Motherboard Name
Read this
http://www.bit-tech.net/modding/2001/12/10/adding_fan_speed_control/1
Take the guesswork out
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope it helps
hope this helps
