Question about Kenwood Excelon KAC-X621 Car Audio Amplifier
Kenwood kac x621 kenwood kac6402
I just hooked the x621 up to two 12's and the 6402 hooked to all my car speakers.i have it all hooked up to a kenwoodkgc9904 equalizer.i dont know what i set the features or knobs on both amps to really make my system bang.i need help to know what my amps should be set to and what levels my eq should be set to make it sound the best
  • Anonymous Mar 24, 2008
    same exept into one 12
  • 62 Answers
May i suggest removing the equilizer unless you can adjust the settings for each amp seperatly. The amps themselves will allow you to add bass boost and treble boost. I think the problem your having is trying to run to much bass through your system causing it to distort badly.
Posted on Mar 25, 2007
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
Amp is flashing a e-02 error
This means the unit has failed and direct current is being generated to the speaker output. Try turning the power off and releasing the protection. If that doesn't work, you will probably need to take it in to an audio specialist because there is an internal problem with the amp.
Feb 24, 2011 | Kenwood Excelon KAC-X621 Car Audio...
X621 excelon amp has red light on, stoped workin all of the sudden now a minimum sound exports with a bit of static. do i reset it? what do i do and how?
If disconnecting all power wires, and replacing all fuses (including inline ones) doesnt reset it. then its toast. Hate to break it to you :( Contact the manufacturer if you feel it is under warranty.
Apr 14, 2010 | Kenwood Excelon KAC-X521 Car Audio...
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
When I hook up my kenwood kac-7201 the power light
leave power connections hooked up disconnect rca and speaker wires if they still blow more than likely problem with amp
Dec 31, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
No sound flashing e-02 in window
Turn power off this will release the protection turn power back on if code is still flashing contact kenwood dealer
Jan 04, 2009 | Kenwood Excelon KAC-X621 Car Audio...
Amp Turns on... then off
unplug all speakers and see if it still into protect .If unit powers up normally without speakers , then hook up a temporary speaker directly to speaker out to see if you have output.If it works .Then check speaker cables and speakers for shorts.Also make sure you have good ground and main power and standy are present.
Nov 30, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood Excelon KAC-X621 Car Audio Amplifier Logo
167 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
