Question about Ovens
Low temp causes heating coil to spark and leave white residue
We have an old frigidaire oven (can't find the model or serial number) in
our rented house. After running it for a while on a low temperature, 200
degrees, the heating coil began to spark. I turned off the oven, but now
there is a white powder residue near the spark area. What is wrong with this thing? Can I trust it not to burn down the house?
  • Ovens Master
  • 3,463 Answers
You need a new heating element fitting.
Do not use it until it is fixed.
The white powder is from the inside of the element.
Please rate this solution.
Ta.
Posted on Dec 09, 2008
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
How do you operate oven
You should have a bake and broil button and arrows to adjust temp up and down. Of course a start button should be there. If no off button, then there should be a cancel button to turn it off. The door only locks in self clean mode.
May 21, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Bottom element stays on oven continues to heat. Temp guage preset stops at setting but element does not got off.
You do not list a model number, but this condition is generally caused by welded contact points in the electronic control. (requires electronic control replacement)
Nov 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven is slow to heat then exceeds set temp set
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Oct 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire package heat pump,in heat mode it goes into defrost everytime it runs for a few minutes,no matter what the outdoor temp.is..it runs about five minutes or so and goes into defrost for...
That is usually caused by either lack of airflow through the outdoor coils. (Dirty coils, need cleaning)
Bad defrost board. (needs to be diagnosed with multimeter and extensive explinations and/or experience to be sure)
Low refridgerant, causing premature freeze up and in turn causing frequent defrost cycle. (Recharge to proper pressures with proper refridgerant type. Requires EPA certification for use of refridgerant, you would also need refridgerant guages, temperature reading device, and refridgerant.)
Dec 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES400 oven controls
Contacts are fused.  Get a new one, cut the power and replace it.
Nov 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
453 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
