Question about Crossfire VR1000D Car Audio Amplifier
Were I've fined how to install or set-up speacker .
    Problem Solver:
  • 12 Answers
The manual or online site.
Posted on Dec 10, 2008
What can i do if my sound of pc donot work?
Try to install correct sound device drivers(Which is provided with motherboard cd),
Set volume control to high in control panel,
check your speacker working fine...
Thannks
Jul 28, 2010 | Computers & Internet
The son froom my speackers stop
my best guess on this one is probably not the speakers but the sound system or device sending the signal to the speakers or the wiring to the speakers is shot if you are sure that all of this is fine then the problem is the speakers do not have enough power to play and it might be the psu that is shot.
Aug 22, 2009 | Yamaha HTR-6030 Receiver
My sound hardware work but i dnt hear nothink in my output speack
Question: Are your speakers plugged in and turned on?
First check the hardware of your speakers, that they are plugged in, to the proper speaker port. then check the device manager to see if it recognizes the sound card /speakers, it not then go to add hardware app and run it , remove sound card and replace it with windows Plug and Play running. if it recognizes it then run your program to see if the sound is playing. Good luck hope this solves your problem.
Jul 12, 2009 | Computers & Internet
Same HP/pavilian speackers and low soung from gx280
save your polks,go to the nearest truck stop store and purchase a set of little loud mouths their called,i guanantee you will hear those.
Jun 15, 2009 | Dell OptiPlex GX280 PC Desktop
Kdc-519 install in 93 mustang
if u have cut the factory harness, then u may have cut the power on wire for the factory amp
Jun 07, 2009 | Kenwood KDC-519 CD Player
Distortion using rear speaker interfaces.
yea get new speackers or u have a very low quality wire also can bet out of eq
Apr 02, 2009 | Pioneer VSX-1018AH-K Receiver
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Feb 28, 2009 | Pioneer TS-A6962R Car Speaker
Need help no sound out of speackers
Presume you mean 790 not 970, if so you can download a manual under product detail on this page.
http://www.amazon.com/Boston-Acoustics-BA790-Multimedia-Computer/dp/B00005AR7N
Check power supply is plugged in correctly and switched on at the socket, then turn or push the button usually on the right speaker to turn it on,
good luck HPC
Sep 27, 2008 | Boston Acoustics BA790 Computer Speakers
Speacker problems
cheak sound card settinsg for 4 ch 5.1 output or in audio main menu ok
Feb 01, 2008 | Logitech X-530 Computer Speakers
Crossfire VR1000D Car Audio Amplifier Logo
81 people viewed this question
Top Crossfire Car Audio & Video Experts
xxxxxx xxx
Rommel Balcita
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
