Question about Sirius Satellite Radio Sirius Sportster SP-R1 Satellite Radio Receiver
SIRUIUS SPORTSTER ANTENNA CANNOT BE FOUND - HAVE TRIED RELOCATING ON THE ROOF OF VEHICLE NUMEROUS TIMES, CHECK CONNECTION INTO THE CRADLE, DO I NEED A NEW ANTENNA?
  • 4 more comments
  • Anonymous Mar 15, 2008
    Same problem have purchased new antenna...still have problem
  • cbaxt Jun 19, 2008
    First got antenna not detected but would eventually work now am getting acquiring signal but never finds signal. I am on my second antenna for my car.Im afraid the sportster is just a piece of junk.
  • Anonymous Aug 16, 2008
    For over two years the antenna on the car has received the signal very well. Suddenly in the past two to three weeks the screen just size no antenna detected or, now, "acquiring signal", but we don't get the signal. I checked the connections and all seem okay. HOw do we know whether to replace the antenna or whether it is something else? Thanks. Charlie
  • mike46717 Nov 25, 2008
    same problem -- my unit worked fine then stopped one day --- now there is the not detected antenna -- I bought a brand new antenna and its still doesnt work ---- how can the cradle be bad --- ?
  • jda2110 Dec 20, 2008
    I get all channels clearly, but screen shows 'antenna' and does not display the song name and artist anymore. Why?
  • D_Nice121212 Mar 17, 2009
    I've had Sirius for 5 years now and throughout all 5 years I have seen the following message, "Antenna Not Dectected", but the message showed on and off. Recently the message has turned into "Acquiring Signal" and will not go away...
    Has anyone received any assistance in this matter? Please provide an answer... Sirius is no help, Audiovox is far from helpful!
I had the same problem before, it ended up being the dock.
Posted on Oct 03, 2007
  • 41 Answers
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Posted on Sep 21, 2007
How do I shift the radio antenna off the roof of my Mazda BT50 onto the bullbar?
remove the roof antenna ( unscrew off the mount) buy an aerial for the bumper. run the coaxial cable back to the radio and pull the existing cable out and after fitting a connector on to the end of the new cable plug it into the back of the radio. It will be a lot of trouble to remove the existing cable and roof mount and you will need it at a later date.
Mar 11, 2014 | Mazda Cars & Trucks
Dlink external antenna configuration
Hi .In my Experience if you Change the Antenna Must be equal Both are Antenna Like 12 dbi Otherwise you are facing the Slow Issue.
must be same DBI Antenna (on my Experience 2700 AP I Face same issue ) when i change the Antenna both are Equal It s Fine working Thanks
Feb 04, 2014 | Computers & Internet
Poor radio reception.I've tried a new aerial mast,no improvement. CD player sounds fine. Any ideas? (Passat Est.2003)
Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 1 Subject: Model(s): Group: Number: Date: AM Radio, Poor Reception 1999, 2000 91 99--07 New Golf, New Jetta, Aug. 2, 1999 New Beetle, Passat Condition AM reception is poor. May be caused by: ? An incorrect antenna mast installed for the antenna base equipped with the vehicle ? Poor ground at the antenna base or radio ? Poor battery ground to chassis or engine ? Poor antenna cable connection at Radio ? Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. If radio antenna masts are removed from vehicles and stored until vehicles are sold, there is a chance that an incorrect mast can be installed at the time of delivery. Note: Mismatched antenna mast and base will cause poor AM radio reception. The antenna base and mast can be identified visually as follows: (Cont. on Page 2)91-A260 requires gloss finish antenna mast 57mm 49mm Bosch 91-A261 requires matte finish antenna mast 61mm 41mm Clarion 91-A262 Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 2 Bosch antenna ? Base (although oval) is more circular in shape (approx. 57mm x 49mm). ? Made in Germany stamped on underside of base. ? Two screws on underside of base are unpainted. ? Requires gloss finish antenna mast. Clarion antenna ? Base is more oval in shape than Bosch (approx. 61mm x 41mm). ? Two screws on underside of base are painted. ? Requires matte finish antenna mast. If antenna mast matches the antenna base correctly: -- Check antenna coaxial cable connections --arrows-- for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. -- Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). -- Check ground at the antenna below roof Nut --4-- (torque = 7+1 Nm) must firmly secure antenna to roof). (Cont. on Page 3)Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 3 -- Check ground for radio behind radio on cross member (On Passat models as of Nov. 1998 beginning VIN: XE285000 ground for radio is on right side of center tunnel). -- Check engine compartment ground, left side, below battery tray; frombattery GND to body. -- Check engine/transmission ground on transmission, near engine block. -- If all grounds and antenna mast are OK. -- Replace antenna and coaxial cable assembly
May 06, 2011 | Car Audio & Video
When explaining that an antenna needs to be 'gounded', does this mean that the bracket the antenna is attatched to needs to be actually hard wired to the vehicle frame or when using a magnetic mount...
Hi, my name is John. Welcome to FixYa. Yes, That is not sufficient enough for your antenna. Need any further information let me know. Thanks for choosing FixYa...John
Nov 23, 2010 | Cobra 29 LTD CB Radio
Fm works but no am. i tried connecting an alpine stereo but still fm works but no am
This problem will only deal with the antenna cable correctly connected behind the unit and up to the exterior roof antenna. Any break in the harness may cause this effect. In early VW's when the antenna was located on the front left fender, owners were complaining of poor reception and static interference from the ignition coil near by. Besides hearing your AM station you also hear electrical noise which changes pitch as you increase the engine speed while keeping FM unaffected. The solution was insulation and relocating the antenna at the farthest part of the vehicle, rear roof. Make sure you have the the right connector for your unit to make a perfect connection.
Mar 16, 2010 | 2000 Volkswagen Golf
I have everything hooked up but all i get is static. I had someone from radion shack check the ground and hookup and they said it all looked good. I have tried numerous CB's and different anntennaes still...
Truck boxes may be the best looking place to mount a CB antenna but in my experience they are the worst place for performance.
The 'ground' you need is not an electrical ground but an RF ground. The easy answer is that you need to mount the antenna to a mirror or the bumper or even use a magnet mount instead on the roof. The body of the vehicle provides an RF ground that the small truck box cannot. The only way it might work is to use flat, wide ground straps at all four corners of your box to the bed of the truck. You need metal-on-metal contact.
Feb 07, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Antenna keeps loosing its satellite connection
ensure the connection into the receiver/dock is not loose. Also check the antenna wire to ensure there are not any places where the wire has become chaffed. Its not uncommon for the antennas to go bad also.
Oct 29, 2009 | Sirius Sportster 5 Satellite Radio...
My sirius radio sportster works sometimes and others doesn't
Buy radio shack electronic contact cleaner (in a can) and spray a small amount on the male connector from the antenna wire, and spray a small amount on the male connector in the base of the Sportster that the sportster interfaces with. Place the antenna connector onto the base unit and remove it several times and swirl it while connected. Place the sportster into and remove it from the base several times. This usually will fix the issue. Sat signals are extremely sensitive to the slightest oxidation or dirt or whaterver on that tiny antenna connection point.
Oct 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Acquiring signal only on display
If under warranty get a replacement. If not, you are beat, they are dead when they stop getting signal and you have tried different antenna. It's sad but true.
Jan 21, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius Satellite Radio Sirius Sportster SP-R1 Satellite Radio Receiver Logo
794 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
