Question about Whirlpool GEW9250 Electric Dryer
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
  • 4 more comments
  • thebohlings Dec 20, 2008
    I have a Whirlpool Duet Electric dryer. When Start is pushed, the "Sensing" light comes on, but it will not run.
  • jones19602 Dec 20, 2008
    When i turn on the start button, I see the sensing light comes on, I hear a click noise from the circuit board, but the drum does not turn/it does not start. I see no burn marks in either circuit board.
  • Anonymous Jan 02, 2009
    I just got this new whirlpool duet dryer... the first cycle ran fine. Now when I try to start it - the power is on but will not start, just beeps.
  • ghunchak Feb 09, 2009
    The Whirlpool Duet dryer turns on, the machine beeps when the start button is held down, but the basket won't spin. I emptied the basket and it made a 1/4 turn before stopping.
  • susan623 Feb 10, 2009
    I have this dryer, the lights come on and it beeps when start button is pressed, but it does not turn or heat up.
  • kristenhyde Feb 24, 2009
    All the lights will light up and it makes beeping noises when it is not in use. It will also not turn at times when you press power.
We had the same problem.
HOW IT WORKS: When the dryer door opens/closes it pushes or releases a little knob inside the door (on ours it is in the top left position). When it is released the light inside comes on and the dryer will not start, it will show panel lights but will beep if you try to start it. When it is pressed (when the door is closed), the light turns off and it will let you turn the dryer on.
Being that the knob was not working properly, there was no communication when the door was opened/closed to tell it to turn on the light or let the dryer start.
SOLUTION: Purchase a new knob, part number 8519323 (also part number 8283288). This comes with both the knob and the wiring, but we only had to replace the knob itself.
REPLACING KNOB: It is easily removed from the outside.
1. Open dryer door.
2. Press (squeeze) the left/right sides of the knob and pull it out.
3. Put in the new knob and press into place.
It was as easy as this for us anyway. The part was approximately $38.
Posted on Feb 25, 2009
  • 36 Answers
Try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Posted on Dec 09, 2008
4 Suggested Answers
SOURCE: Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer
Has anyone found the answer to this
Posted on Jul 17, 2011
aborcass
  • 2651 Answers
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Posted on Mar 25, 2009
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Can not get my dryer to turn on
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
FRONT BELLOWS
I have a whirlpool duet washer i can't retrieve the model number because the door is locked but the dryer which is the match to the washer is model number GEW9200LW. My question is that when I hit the control button then start, a muttled beep will sound not allowing the door to open. I get an error message of DL then it flashes to F? Any help?
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
375 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
