Question about Cameras
Very small spot on photos , like a water spot
    Genius:
  • 1,199 Answers
Try another memery card!
Posted on Dec 09, 2008
Ink spots on back of printed page from Canon i860. What to do?
Type in your search engine How to get rid of ink spots on back of printed page from Canon i860 printer.
It will take you to How to download a manual that will help you fix this issue. PDF.
Jun 18, 2017 | Canon i860 InkJet Photo Printer
My Panisonic Lumix was dropped in the lake in its case last summer. I dried it out and it still works great. The only thing is now when I take photos of things that are dark like night time photos or a...
If these spots are in different places on each picture, then they are actually reflections of dust particles in the air from the flash being so close to the lens. If they are in the same place on each picture, then they are indeed water spots on the lens.
Mar 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
It's a small black spot near the bottom left. It
it sounds like a small pieces of dirt got inside the photo mechanism and may need to be clean proffesionally
Jul 21, 2010 | Canon PowerShot SD1100 IS Digital Camera
Water is running through refill tube into overflow but bowl will not fill.flapper seems to be sealing,I even hold it down and will not change wwter level in the bowl.Where can the water be going?(CST924F)
Unless the water is running out onto the floor, the ONLY place it can go is into the toilet bowl. The amount of water in the bowl (known as the "water spot" - which is a reference to the size of the surface of the water) can be no greater than what the geometry of the bowl and trap will allow. Unless the trap is clogged, the height of the water spot is determined by the trap. Some newer toilets have a pretty small water spot. To confirm the size of your water spot, very slowly pour water into the bowl from a bucket.
Jan 29, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
White cloudy spots on my images - a recent problem
If these are like "bubble" spots and they appear in different places on each photo, I'm guessing you're shooting flash pictures indoors. The spots are dust particles in the air reflecting the flash. This happens on small point-and -shoots because the flash is almost in the same plane as the lens.
Nov 10, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Dull Round Spot
I cleaned via computer the printer and the matter was solved.
Nov 25, 2008 | HP Photosmart A617 All-In-One Printer
Getting spots on photos
I pulled out the cartridge that was causing the spots, dabbed at the small pool of ink that collected with a very soft paper towel, re-cleaned the print heads and that seemed to solve it...
Jul 11, 2008 | Epson Stylus 1400 InkJet Photo Printer
Spots on Image sensor?
put in p mode and go to the sensor cleaning function you need whats called a lens pen it will clean those spots easy just be gentle.
Nov 10, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Spots on image when using built-in Speedlight flash
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
