FixYa.com
Tags:
Audio Pro 15PLB76 15 Inch 800 Watt Woofer Car Speaker
What about component speakers - Do they sound... (by 2 users)
By Peter1 - usenet poster
What about component speakers - Do they sound better?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by balla13, posted on Dec 20, 2007
okay, so im about to put a system in my car... It is a honda accord, so im getting components for the highs up front, but should i go 2-way or 3-way on the 6X9s in the back? what are the advantages and disadvantages...
Best Solution
posted on Aug 08, 2005
Thanks for Trying (70)
maartenw
maartenw - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Component speakers, also call separates, are a separate midrange and tweeter. The midrange can be mounted in the factory opening and the tweeter up higher on the door or dashboard. Component speakers are typically better sounding because the audio signal is split up so that the midrange frequencies are routed to the midrange speaker and the high frequencies are sent to the tweeter via a crossover. This allows each speaker to play the frequencies they were designed for. The other important reason that separates sound better is because you can move the high frequencies up closer to your ears. High frequencies are very directional. If the factory location of the speakers is low in the door or dashboard, the high frequencies are lost into the side of your leg or under the dash. The challenge with separates is mounting the tweeter so it is secure and cosmetically pleasing. A certified installer can handle this type of installation. A separates installation may modify the door panel or dashboard as part of the mounting so they will need to remain in the car when it is sold or the lease ends.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 07, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I have a 12 inch orion comp and i am putting it in a ford windstar along with 2 10inch speckers. what size box should i build?
Solution #3
posted on Sep 12, 2007
Not Rated (0)
madmike20
Rating: 70%, 1 votes
Honestly i think it has to do with the person that is going to listen to the sterio.I personally recomend component 3 way speakers.They can be mounted in place of the factory speakers.You ain't got the visual affect of having tweeters hangin around also.If u get the right brand component speaker they will sound just as good as "hanging" tweeters and spending the money to modify the kick panels,dashboards,and consoles.
This Problem Also Relates To: Audiovox BA200 Car Subwoofer Cobra HG-S500 Car Speaker Jensen JX1200 Car Subwoofer Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Sony Xplod 240 Watt 6" x 9" 4-Way Speaker Car Speaker Sony XS-L1035 Car Subwoofer Sony XS-L1036 Car Subwoofer
Can you Help with these Car Speakers and Subwoofers problems?
i have a kenwood KDC-MP439
i have a kenwood KDC-MP439 and... Answer This...
i have a jvc car
i have a jvc car radio and i... Answer This...
looking for a code for
looking for a code for my benz... Answer This...
Audio Pro 15PLB76 15 Inch 800 Watt Woofer Car...
car speaker installation
my 2003 silverado truck has... Answer This...
Sub Woffer System
Just had a sub woffer syster... Answer This...
Repair Service
Find Car Speaker and. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
