Question about Garmin Nuvi 660 GPS Receiver
Buttons on screen jump around
The problem started on my NUVI 660 about three months ago. (Its almost 1 year old) after its on, I try to enter the pin number and the screen number buttons jump all around. For example If I want to tap 3 it jumps to 7. After much frustration getting through that screen it does the same thing when trying to enter a destination. Should I just send it back to the company/ factory? What can I do since its almost 1 year old? Thanks any help is appreciated.        Lindsay
  • lindsaylou Dec 10, 2008
    I am trying the first solution, hopefully this will do the trick. Thanks so much for your prompt help.
  • Garmin Master
  • 2,130 Answers
Ok I have a few questions. When you mean it jumps around do you mean:
1. When you press a 3, the 3 button becomes a 7 graphically or
2. When you press a 3, the 7 button is highlighted and chosen.
The first thing I would do is try to recalibrate your touchscreen by pressing the wrench symbol, then the display icon and select calibrate screen. Press the series of dots as you are asked to do and see if that clears up your problem.
If that doesn't work, then I would do a reflash/ugrade of the firmware. Perhaps the firmware is corrupted. This can be done by dowloading Garmin's webupdater at www.garmin.com and connecting your Nuvi to your PC and letting the program reflash your firmware.
The last solution is to replace the touchscreen. Are you sure the screen is not cracked anywhere? A cracked screen will certainly cause a touchscreen to either not work or activate another button when pressed.
- Jim
SHARCNET-USA
If that doesn't
Posted on Dec 09, 2008
The screen is locked up and won't respond to touch
keep telling me enter pin number. I don't know the pin number. I for got it. I had two year ago
Jan 05, 2011 | Garmin Nuvi 660 GPS Receiver
Forgot pin
There is a reset button, but it will NOT reset the PIN. Take the unit to the location at which the PIN was first entered and it will unlock. You can then change the PIN to something you can remember.
Apr 17, 2010 | Garmin Nuvi 660 GPS Receiver
Neither of us remember password for garmin 660 how do u reset?
You have three options for unlocking a PIN locked Garmin:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was entered
3 - Send the unit back to Garmin
Unfortunately, these are your only options as this is a security feature to prevent unauthorized use of a stolen GPS
Jan 31, 2010 | Garmin Nuvi 660 GPS Receiver
Unlock garmin gps
Unfortunately, these are your only options as this is a security feature to prevent unauthorized use of a stolen GPS.
I lost my pin for my gamin nuvi
Jan 28, 2010 | Garmin Nuvi 660 GPS Receiver
So i found a garmin 660 on the side of the road a couple years ago. Obviously someone stole it out of a car, relized it had a security pin, and chucked it out the getaway car, lol. Anyways i went to the...
The problem you have is the same problem the thief had - you cannot use this unit. The only way(s) to unlock the unit are:
Be aware, however, if you send the unit to Garmin to be unlocked and you are not the owner of record at Garmin, they WILL NOT return the unit to you.
Jan 17, 2010 | Garmin Nuvi 660 GPS Receiver
Unlock my pin code
You have three options to unlock a PIN locked Garmin:
2 - Take the unit to the location at which the PIN was set.
3 - Send the unit back to Garmin.
Jan 10, 2010 | Garmin Nuvi 660 GPS Receiver
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Can't find Satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps....
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Jul 05, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 forget my pin
The only options you have when it comes to a locked unit is to enter the correct PIN, go to the location where the PIN was set, or send the unit back to Garmin. There is no way to unlock a PIN locked unit without the correct PIN or location.
Jul 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
121 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
