Question about Refrigerators
Kenmore mini fridge too cold
Kenmore mini fridge freezes all contents even when set to the lowest setting.
  • humerlis May 06, 2009
    Mini fridge freezes all contents when set at lowest setting
2 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Kenmore mini fridge freezes all contents even when
Your mini has no timer , heater , bimetal . It has to be defrosted manually . The freezing is caused by a bad thermostat . This small aluminum tube is connected to the bottom of the freezer coil . If you can pull out the thermostat body ( piece with the knob ) and look for a small hole where a small screwdriver can be inserted , you may can try turning the inside small screw clockwise to raise the operating temp . If not , replace the mini . Est $100.00 .
Posted on Jul 16, 2010
Maytag Dual Cool - fridge side too cold even on lowest setting - freezing vegtables
It's just as previous person, on warmest setting vegetables and meat are freezing in drawers
Apr 10, 2013 | Maytag MSD2651 HE Side by Side...
Fridge compartment is freezing contents, freezer is OK however. controls have been set to lowest setting for 3days now
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 09, 2011 | Westinghouse Refrigerators
Our amana fridge fruit and vegetable bins freeze the contents. Fridge is set at lowest temp.
heatman101
Jul 27, 2011 | Refrigerators
I'm not sure which one I have, but purchased my approx. 2 yr. old Kenmore bottom freezer refrigerator from a trusted contractor doing some work in my home. I have a problem with the left produce bin......
Cold air from freezer blows into refrigerator compartment right behind that tray. Freezes stuff in that tray. Pizpoor design. Known issue. With GE refrigerators also of same design. That kenmore most likely was build by GE. GE/Kenmore deny the issue but thousands of posts online about it. No solution. Sorry. Good luck.
May 19, 2017 | Kenmore 62832 / 62834 / 62839 Bottom...
Kenmore mini fridge freezes all contents even when set on lowest setting 1
three things you have to check your defrost timer,your defrost thermostat, and your defrost heater you would need to use a multimeter on all three of these and check for continuity between each side of the terminal ends the one that gives you no continuity is the one that you would need to replace hope this helps
Jun 26, 2010 | Refrigerators
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Refrigerator freezes contents
Get a new cold control for it
Sep 01, 2007 | Refrigerators
Refrigerators Logo
730 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
