Question about Hitachi 53SBX59B 53" Rear Projection Television
Picture flickers when T.V. is tapped on or struck.
Hello! I have a Hitachi 53SBX59B 53" rear projection television. The unit will power on but no picture is present. I have taken off the upper and lower rear panels and cleaned the dust off with compressed air. The picture blinks on momentarily sometimes when I lightly tap the unit, sometimes when I hit the side of the unit, and sometimes just randomly. Other times when I do tap or hit the unit, the picture does not flicker on at all. I would appreciate any advice or suggestions. Feel free to ask me any other questions that might help give you insight into what the problem may be. Thank you for your time and willingness to help. - Zappajax -
    Problem Solver:
  • 10 Answers
Sounds very much like a loose connection, i.e. a wire or solder joint, you could have a look around make sure everything is plugged in right, as for the solder joints id advise getting it proffessionally looked at as these rear projection tvs can be a lot of hassle if you slighty knock any of the 3 tubes,
Posted on Feb 26, 2007
No picture
OK, the set is on if get the menu display and you have sound--either a video circuit problem or a glitch.
Do you get picture via the rear audio and video input jacks? this will rule some things out.
Also if not tried disconnect set, any box used, or a receiver from power for several minutes and power back (possible glitch).
Dec 21, 2012 | Hitachi 53SBX59B 53" Rear Projection...
I would like to sell our 53 projection Hitachi TV - is it worth anything?
A couple of hundred is what they are going for now, everyboby whats a LCD
Aug 18, 2011 | Hitachi 53SBX59B 53" Rear Projection...
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
Picture movement and lines
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Google “Hitachi convergence repair” and you’ll find many sites that will educate you on how to repair and where to get the parts needed for your Hitachi PTV.
Sep 01, 2010 | Hitachi 53SBX59B 53" Rear Projection...
My mirror is broke in my big screen do you have to buy a special mirror or can you use any mirror?
The mirrors are specific to the unit as they have slight curves to bend the picture correctly so it aligns to the screen properly. To ensure you get the correct picture for your unit, you would have to order the manufactures original replacement part. You can order an new OEM replacement mirror for this model (53SBX59B) from a major Hitachi parts distributor at the link below:
Hitachi 53SBX59B Replacement Part Mirror / 53" Inner Mirror
Apr 13, 2009 | Hitachi 53SBX59B 53" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Digital Compatibility
TVs, VCRs, DVD players, camcorders and video games will continue to work, even if they are only analog-capable. Such equipment, however, may not provide digital-quality picture and sound.
Hope this helps.
Feb 16, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 53SBX59B 53" Rear Projection Television Logo
134 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
