Question about Pioneer VSX-D712 Receiver
Shows to be stuck in Standby.
My receiver has been working fine for about 3 to 4 years; I recently moved and set it up again with all the same items it had before. About 1 day after I had it hooked up it was playing from the tuner and when I walked by it suddenly turned off. I went to hit the power to turn it back on and what I get is the ?Stand by? light above the power button flashing. When I hit the power button on the remote or directly on the stereo the light turns solid red for a bit then goes back to flashing. I unhooked everything from the receiver including the speakers and tried again it did not work. I tried unplugging it from the wall for 30 seconds (usually resets electronics) and plugging it back in. no change. Any help would be greatly appreciated!!
  • 2 more comments
  • Stephen Archbold Mar 20, 2007
    Thanks for the Solution Techman, I accidently click on average for the little rating thing, I did not mean to.
    I will have a look and call Pioneer Support, If I can ever get home from work to catch them while they are still receiving calls.
  • Stephen Archbold May 30, 2007
    BlueDog 2 you sir.. are the man!!!
    the system came up with out trouble and is working perfictly again!
    BlueDog2.... you sir, are the man!!
    I tried what you suggested and the system came on and works 100%!!!
  • KORG121 Dec 16, 2007
    I have exactly the same problem with my pioneer receiver, and I would greatly apretiate any help you can give me._ Thanks a lot
    Daniel
Hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
Posted on May 28, 2007
  • Wanda Wyatt
    Wanda Wyatt Apr 06, 2013
    Sorry Bluedog--I tried this several time and it did not work.
Hold down Advanced Surround and Enter at the same time for a few seconds
Posted on Mar 11, 2011
  • Wanda Wyatt
    I tried it--it did not work. Thanks
    President:
  • 3,130 Answers
If a unit suddenly shuts down and there is no sound most of the time that indicateds there is a fault in the amp circuit of this reciever. these are solid state printed circuit boards and you will need the knowledge on how this amp circuit works. Depending on what the problem is will determine if the reciever is worth repairing or not. Generaly, if a reciever is over 4 years old it would not be wise to drop any money into it as the capacitors and components in this unit are starting to get weak and will start to fail one by one, you will start nickle and diming the thing. Time I think to go out and shop for a new reciever, unless of course you get a service manual and know how to work on solid state printed circuit boards. Good Luck
Posted on Mar 20, 2007
  • Wanda Wyatt
    Hi Larry, I know how to do some. I need to find the service manual on it.
AMP ERROR DISPLAY NO VOLUME
This is how to reset the receiver to factory default- not sure if it is the same reset you would do for an amp error:
Resetting the system
Use this procedure to reset all the receiver's settings to
the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the front panel STEREO/A.L.C
button, press and hold
u STANDBY/ON for about two
seconds.
The display shows RESET?.
3 Press the front panel AUTO SURR/STREAM DIRECT
button.
The display shows OK.
4 Press HOME THX to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
Note that all settings will be saved, even if the
receiver is unplugged.
Unfortunately, amp errors are usually not fixable and require you to bring the receiver on for repairs or just buy a new receiver.
THANK YOU AGAIN SO MUCH! I basically got through the 1st step or so and the thing came right back on like nothing had ever happened. Although, I think what ended up working for me was actually pressing and holding the STANDBY/ON button with the AUTO SURR/STREAM DIRECT button together for a few seconds....I didn't have to reset to factory settings, nor did I have to do step 3 or 4.
Now the receiver is working just fine like nothing ever happened. All of the input AND output speaker channels all seem to be functioning normally and in peak form, and I've made sure that I have the area around the receiver well ventilated. So....thank you, again...for getting back to where I really wanted to be without having to go through the hassles of disconnecting everything and having it serviced with possible $ and time expenses.
Oct 16, 2013 | Pioneer DEH X3500UI - radio / CD / MP3...
Keeps shutting off
I think there is problem in the way u switched it.
There is some problem in connections.
If possible check all connections once again  and also chek all plugs. Check whether they r working properly or not....
All the best
Oct 18, 2007 | Denon AVR-1707 Receiver
How do I know if oys a fuse blown
I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.
- Leave your remote away as you won't need it
- Turn off the the unit to STANDBY mode
- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.
- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL
- Press STRAIGHT button until it shows INIT **** ALL
- Press Power to turn off the machine.
- Leave it for 2 sec. then turn on the machine again.
Now your unit turns to factory default setting.
Sep 22, 2013 | Panasonic SA-HE70 Receiver
Everything works except for mp3 when i plug it in. doesnt even say aux on screen
Just figured this out !
1) You have to be in 'Standby' mode - press (SRC) until it shows standby.
2). Press and hold 'Menu' button.
3). Using the joystick - move it left or right until it shows 'AUX' 'OFF'.
4). Move joystick up or down until it shows 'AUX ON1'.
It should now work ! - This is on P.22 of the manual - but it actually starts on page 19 where it describes 'Standby' mode.
Aug 03, 2010 | Kenwood KDC-MP205 CD Player
Unable to get my ipod to play through my stereo even tho its plugged into the aux socket
Jul 26, 2010 | Kenwood KDC-MP205 CD Player
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Resetting the main unit
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
shows in the display.
4 Press SOUND RETRIEVER to confirm.
OK
appears in the display to indicate that the receiver has been reset to the factory settings.
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Pioneer VSX-D712 Receiver Logo
817 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
