Question about Siemens Efficient Networks SpeedStream SS1020 Network Adapter
Siemens RDE20.1 upper temperture setting
I have a seimens rde20.1 themostat and would like to set the temperture above 35 degrees which is the upper limit of this unit. I am using it to control a spa pool and want to set the upper limit to 40 degrees? How can I set above the 35 degree point?
cheers Roger
  • 3 Answers
Hold the return and + button at the same time for at least three seconds, then adjust the indicated temperature down which tricks the thermostat in heating to a higher temperature before the set point is reached.
Posted on Dec 10, 2008
I need to know the right temperture settings cause i dont have a manual
dont try to lower cool setting below 70 degrees or heat setting above 78 degrees. all a/c's are designed for a 95 degree ambient when it gets above that you have to increase tonnage to compensate.
Jul 30, 2015 | Heating & Cooling
Honeywell thermostate will not kick off on set temperture
There's a "throttling range." The unit starts (say, in heating) one degree below setpoint and shuts off two degrees above set point.
You can change the "temp" but you can't change the throttling range.
Mar 02, 2014 | Honeywell Programmable Thermostat Heater
Set temperture
Typical settings for a refrigerator / freezer:
Fresh food compartment is around 35 - 36 degrees F,
Freezer compartment is anywhere between -10 and 0 degrees F.
Jun 11, 2013 | Refrigerators
It is over heating and i can't find the temperatre gauge under the hood...
first of all check the radiator for leak or blockage. make sure the coolant is fresh. follow th eupper radiator hosr to the emgine block. there should be 3 bolts attached the themostat housing. take the themostat out and put it with hot water, maks sure the opens. the temperture sending unit should be directly under the themostat. msot likely the themostat is cause or the problem. unless the temperture gage is not reading correctly.
Jun 09, 2009 | 1998 Mercury Mystique
How to activate airtel{india}internet in seimens a55 phone
call 121 and wait for the gprs option
then talk with customer support and ask 4 gprs settings .
they will give u within few minutes .
save it and enjoy gprs
good luck.
Feb 08, 2009 | Siemens A55
Freezer and Fridge at wrong temperture
How old is this fridge? Your themostat may be shot. Put an accurate thermometer in the freezer and cooler to ge the real reading. If they are the same as on the door then the themostat is probably the problem. If not, it could be that all you need is a new display.
Dec 17, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Siemens Efficient Networks SpeedStream SS1020 Network Adapter Logo
362 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
