Yes, I have a Magnavox Observation System Monitor 42MS405T and a camera 18MC 205 T. At this time I am interested in replacing the monitor with the same or replacement product. What is your recommendation and where I purchase it? From Scottsdale, AZ. Thanks, Rea
4 Suggested Answers
  • 4234 Answers
SOURCE: I have a Samsung B/W
The vertical Ic either has bad connections or is defective. Look for a small flat IC attached to a heat sink with about 11 pins. Try resoldering the pins first. If that fails to resolve it, replace the IC. This IC may be marked LA7837 or something similar. If you are unsure, post the marking here and I'll confirm you have the correct part.
Dan
Posted on Aug 28, 2008
Zero-G
  • 33 Answers
SOURCE: 51 inch magnavox - scratch in screen
I dont know if they sell them but Philips has parts distrubitor
phone # 1-800-432-8542
also try 1-800-638-3328
good luck, I dont expcet any of that is cheap...
Posted on Nov 20, 2008
SOURCE: i need cameras for 12tx3512/17w
I have 3 MC3511 cameras.
Posted on Mar 23, 2009
No preview image
Hi there:
You can view pictures in the folder when connected the camera at pc monitor? but cannot take pictures or movies... the LCD stays blank?
If this answer is yes, could be a problem with the CCD image sensor, if no, your LCD display go to bad and will need replacement.
Check this interesting article about bad CCDs.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 07, 2012 | Nikon Cameras
Garmin 205 and heart rate monitor
What is the problem?
If you are looking for a heart rate monitor, one can be found here.
http://www.gpscity.com/garmin-heart-rate-monitor-with-soft-strap.html
Jan 05, 2012 | Garmin Forerunner 205 Gps Training Watch
Jensen VR187 radio/backup camera observation monitor won't work
In the manual look on page 10 step 10. You have to use a ball point pen and straightened paper clip (better) to reset the unit. There is a small hole at the lower left of the Volume knob. That's where you insert the paper clip.
Aug 09, 2009 | Audiovox Jensen JTFT-250 2.5 in. Handheld...
I need a cord I need for an observation cam from magnavox
Strange, I have the opposite problem, I have the cord and camera, but no monitor. I found the following fix below to make this camera hook up to any tv or monitor, but it's greek to me. It may help you though! Or, if you can translate these instructions for me to hook up mine, I'l happily GIVE you my cord!
"The DC power was sent up the coax and the video is AC coupled and sent back down. If you open the
camera and trace the wire from the center pin of the UHF connector, it will lead to an inductor
and a large value capacitor. The video is coupled through the capacitor, which blocked the DC
power from the video output amp. The inductor (coil) blocks the video from getting back into the
power section.
Cut the inductor loose from the center wire of the connector. Put well filtered +12 VDC at 500
mA (1/2 amp) or greater into the inductor at this point while running a video cable from the jack
to a video monitor or to the video input of your home VCR. Then you can see the video on your TV.
Power return is to the ground of the connector or any other convenient grounding node.
Jan 28, 2009 | Philips Magnavox 27MS343S 27" TV
Vga problem in a old system
Thanks for showing your interest in Fixya. Make sure the monitor cable is plugged properly or not. Remove the monitor cable and and power on the monitor. now you could see a message saying that monitor cable is unplugged. If that message appears then monitor is functioning properly. There is a problem in your display card. Replace it with new display card. Insert the new display card into PCI slot of the motherboard. Thank you....
Sep 12, 2008 | Gigabyte Computers & Internet
Samsung B/W Observation System - Model# SSC-12
I have the same problem and I found out that a resistor went bad and then a capicator went bad.you must have them check and replcaced
Oct 26, 2007 | Samsung Weather Resistant Security Camera...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
