Question about Nokia N70 Cellular Phone
My n70 is hard to open and take several minutes to open it and the logo won't show can you fix it
Its already fix... i put it in uncooked rice for 24 hours.. i just follow the instruction that they send me... thanks a lot...
Posted on Dec 10, 2008
My MSI windpad won't turn on, it only shows the animated MSI logo over and over and it won't even turned off.
this shows that the hard disk of computer may be corrupt, or the operating system may gone bad, check these, or re-installtion of OS is recommended in such case
Jan 08, 2013 | Computers & Internet
Tip
Factory Reset for Tungsten T5 handhelds
If you've set a password on your device, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your handheld, launch the Prefs application. From the list that appears, under General, select Security.
2.If the Password box says "Unassigned," tap the box and create a password for your handheld.
3.Once the password has been set, hold down the Power (on/off) button on your device.
4.While holding down the Power button, turn over your device so that you can see the back of it. Still holding the Power button, use an unfolded paper clip or a similar small object to gently press the RESET hole (where?). Keep holding the Power button throughout.
5.While still holding the Power button, the screen will show the Palm logo and a progress bar will appear at the bottom. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
6.A message will appear warning that you are about to erase all the data stored on your handheld. Press UP.
7.You may see a screen that says "Reformatting in progress. This may take several minutes." This screen will remain for several minutes (up to 10 minutes). Don't do anything while this is happening.
8.If you performed this reset correctly, the screen of your device will go blank after several minutes, and you will not be able to turn on your handheld. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again)
9.Your device will appear "dead." To wake up your handheld, perform a soft reset.
on Mar 11, 2010 | Cell Phones
My nokia n70 will power on but just has a blank white screen. it will not go beyond the power on lights. it doesn't even play the the nokia logo screen.
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Sep 20, 2009 | Nokia N70 Cellular Phone
N70 showing white screen with nokia logo only
proceed to THEMES and then select w/c theme you prefer .
Sep 02, 2009 | Nokia N70 Cellular Phone
N70 not switching on
take the battery out, leave for 2 minutes then put it back in and see how that goes
May 31, 2009 | Nokia N70 Cellular Phone
Hang nokia N70.. how will i be able to fix that? pls help
go to ur nearest care center coz i need to change ur software
May 11, 2009 | Nokia N70 Cellular Phone
Nokia N70 Screen is White and shows NOKIA only
Open the back cover of the phone and remove the battery,the try blowing it hard where the battery pins are for 10 minutes or so then switch it back on.Your phone will run smoothly,but only for a short period.The best option is to press the *,green,3 at the same time after blowing the phone.if it does not want to work then let me know.josephsimaneka@aol.com
Dec 25, 2008 | Nokia N70 Cellular Phone
Hi!!! i have a problem on N70 phone.
Sounds like a short..Take the battery off the back of the phone and see if the moisture indicator is active, Usually a red dot will appear. If so, you warranty is voided, contact the insurance program thru your wireless provider if you have it, *TIP* ALWAYS get insurance on cell phones if they are used by kids of people who work outdoors and expose the phone to extremes** If the moisture indicator has not been activated, and the phone is less than a year old, call your cell phone provider for a warranty exchange.
***HINT***
If you ever do get your phone wet, turn the phone off and remove the battery right away. then put the phone in a bowl of uncooked rice and leave it there for 24 hours, the rice will absorbe the moisture and may save your phone.
Dec 09, 2008 | Nokia N70 Cellular Phone
Bluetooth operation problem
you need to go technician then ask them to reformat your n70 phone,so that it will work well.
Nov 22, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
