Question about Toshiba Satellite 5205-S503 Notebook
Satellite 5205-s505 speakers aren't working, headphones OK.
Got a used 5205-s505 on eBay, presumably in perfect condition. Laptop arrived, I boot it. No sound at all during the boot. Checked the settings to make sure it's not mute. Looked ok. Try to play CD, no sound. Listen carefully, heard very slight buzzing sound from speakers. Try to listen through headphones: fine! Contacted seller. He claims he tested the laptop before shipping and everything was fine. I can't imagine something happens with speakers during the shipment. At this point I'm still trying to figure out if there is anything I can try to verify speakers are dead - or not.
  • 107 Answers
Start- Control panel- Sounds and Audio Devices- In the device volume section click Advanced- Click Advanced again and check if In the other controls section 1 PC Spk mute is checked if so uncheck it If that does not work please let me know so I can help you further
Posted on Dec 09, 2008
Can i use any charger on s505
The Toshiba Satellite 5205 series of Notebook PC, and the S505 series model; uses an AC adapter (Charger) that produces 15 Volts DC.
http://www.sparepartswarehouse.com/Toshiba,Satellite,5205,PS520U-31P1RV,Laptop,AC-Adapters.aspx
You will see AC adapters sold that show 15 to 24 Volts. (DC)
http://www.duracelldirect.com/toshiba_satellite-5205-s505_ac-adapters_laptop_ac-b20h.aspx
This is because the AC adapter (Charger) has PFC.
Power Factor Correction,
http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-Power-Supplies/181/2
Also I see it is just a two pin AC adapter plug, to laptop.
Center hole is Positive, outer metal cylindrical metal shell is Negative.
Go for 75 Watts or higher though, and not a 65 Watt model.
[ On the case of the AC adapter;
Input: 100 ~ 240 VAC 50-60Hz
Means it can use from 100 to 240 Volts AC, and either 50 or 60 Hertz.
Output: 15VDC 6A
Means 15 Volts DC at 6 Amp's. (Amperes)
Watch the outside dimension of the cylindrical part, and the center hole dimension. Outside cylinder may be correct, but center hole may be too small. Or vice-versa.
Regards,
joecoolvette
Dec 17, 2012 | Toshiba Satelite 5205-S505 Notebook
My toshiba laptop powers on but doesn't boot up to windows until after i open and close my dvd drive
if there is a quick release for the drive - pop it out entirely and see if works then. You are looking at replacing the drive or motherboard.
Feb 25, 2011 | Toshiba Satelite 5205-S505 Notebook
My laptop could not entering into the main desktop after booting, only loading.
I think your windows has corrupted . Try the following.
Boot the system and hold F8 key.
Select the Last known Good Configuration.
Rebbot the system and then check
Mar 16, 2010 | Toshiba Satelite 5205-S505 Notebook
CPU upgrade for Satellite 5205-S505
You would only get a marginal performance increase. If your laptop has 256Mb of RAM, increasing the RAM up to 1Gb (this model laptop cannot support more than 1Gb RAM) would boost the performance of the laptop.
Jun 20, 2009 | Toshiba Satelite 5205-S505 Notebook
Mini-PCI WIFI in Satellite 5205-S703
Check out if you are inserting it properly into its slot. That that can be one reason.
another thing you can do try is to try to put in after you have already started the computer and you in windows.
Feb 09, 2008 | Toshiba Satelite 5205-S505 Notebook
Replacement of Hinges for screen of Toshiba Satellite S2410-603 model
You can check on www.ebay.com by typing Satellite S2410-603 and check there for a possible part.
Nov 12, 2007 | Toshiba Satelite 5205-S505 Notebook
How can I install my recovery CD's if my DVD/CD drive doesn't work
I had a similar problem with an IBM thinkpad once. My solution was to purchase a PCMCIA CDROM drive and boot from that. Go to: http://froogle.google.com/frghp?ie=UTF-8&oe=UTF-8&hl=en&tab=wf&q= and search for "PCMCIA CDROM". Your laptop should boot from one of these devices.
Feb 14, 2007 | Toshiba Satelite 5205-S505 Notebook
Toshiba Satellite 5205-S503 Notebook Logo
176 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
